Question about Brother IntelliFAX 2800 Laser Fax
Straight line comes up when i make a copy or fax to some one
I just bought the drum and everytime i make a copy or fax some comes up with a straigh line
what should i do?
  • 215 Answers
If your received faxes look good and this only happens when you fax someone or make a copy, lift up your document feeder and you will see a glass under it that is about an 1.5" wid and runs left to right. something is on that glass. perhaps whiteout or something like that. clean that off good and you should be fine. if it doesn't take care of problem, write back.
Posted on Feb 12, 2009
When making a copy on the fax machine, it has a la...
your must clean scan unit ,mirrors and check drum .make a white copy if the problem occurs change drum unit
May 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Lines appear on copies
if the line is from the button to up must change the cleaner or you do the trick of cleaning it by any alcoholic liquid
and if the line appear only in the printed area so you must change the drum
May 06, 2009 | Office Equipment & Supplies
Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Apr 13, 2009 | Brother MFC 9180 All-In-One Laser Printer
4100 when I copy I get a black line down the middle Ok after cleaning inside top cover, but,comes back after a few copies. Printing and sending fax ok.
Try printing out a report. If the line is still there you need to use the wire cleaner on your print cartridge or if that doesn't work, replace the drum unit.
Apr 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Lines and breaks on docs received by other party.
Hi
If you have lines when faxing out it cant be the drum,If you have lines with copy and receiving faxes then it can be the drum.
I think you problem is a dirty scanner glass.Check the glass and clean.
Nov 18, 2008 | Office Equipment & Supplies
Lines on page
As far as copying goes, it could be lines on the scanner glass. You might want to check that out.
Do you have any way of checking the condition of the drum on the cartridge to see if there are any lines on it. Find the drum cover protector by removing the drum cartridge straight up, lift the drum protective cover and see if there are any lines on the green surface. Try to keep it out of direct light as much as possible. Make sure you lift it straight up so no toner or developer spills out.
I've seen a few cases where the cleaning blade on the drum is defective. Usually you can return them and get a replacement at no charge.
Jun 23, 2008 | HP LaserJet 3055 All-In-One Printer
Black line need help
where you insert the drum, look in the machine on top there is a glass wipe it
Jan 22, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
