Question about Bernina Artista 180
Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
I only use the machine a few times a year, mostly for straight stitching. 2 years ago I had the same problem and to fix it, I took it in for servicing ($120). Today is the first time since then that I needed to use the zig zag or buttonhole. I have had the machine for over 20 years and it never did this before.
  • 202 Answers
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
Posted on Feb 13, 2009
  • 3 more comments
  • thespeidels
    thespeidels Aug 16, 2012
    THANK YOU, THANK YOU, THANK YOU!!! That was ALL my machine needed!!! I think because that is not a normally moving part, it never gets oiled therefore the oil that was there was probably old and gummy...thanks again!!!
  • aeteel
    aeteel Oct 16, 2012
    whoa! this just worked for me too. its soooo awesome thansks so much
  • Kimberly K Aug 10, 2013
    Thank you so very much, that was just what my 830 needed too. Explains why sometimes the zigzag worked and sometimes
  • Joy Redhead
    Joy Redhead Aug 15, 2013
    This worked for me, too, but I sometimes still have to push the part into the groove with my finger. Maybe it will loosen more with time and when the oil really moves into places where it is needed. Thanks!
  • Paerewyck
    Paerewyck Apr 06, 2014
    This did the trick...I thought it hadn't at first though so, if I can add anything to the above, I'd note that you know that the parts has loosened sufficiently when that lever (zigzag vs. other stitch settings) actually 'clicks' into position on either side of its range.
  • Bernina Master
  • 10,777 Answers
If your machine has not been professional serviced recently or you have not cleaned and oiled it lately, then you might refer to your owner's manual instructions for oiling. I would suspect that perhaps the oil has hardened and is preventing the machine from operating properly--perhaps some of the selector lever/dial mechanics are not moving internally. Use liquid Tri-Flow Synthetic Oil (usually available at the hardware store) and put a drop or two every place that the manual recommends. Direct a hot hair-dryer into the internal works of the machine. (I usually let it get pretty warm to the touch - but make sure to stop periodically because your hair dryer may overheat.) Test your machine. If you can determine that the selector lever/dial mechanics are not moving, you can try putting a drop or two of oil in its metal joints and working it gently back and forth to loosen. Depending on how hardened the oil has become, you may have to repeat oil/hair-dryer process several times before things loosen up. Once it is working again, be sure to clean and oil regularly. (I recommend a good quality oil, ie Bernina oil for mechanical machines. It may seem expensive but it lasts a long time if you use only one or two drops each spot and, IMHO, is worth it in the long run. I do NOT recommend 3-in-1, WD-40, cooking oil, or the cheap sewing machine oil from fabric departments.) You have a wonderful machine and it will continue to serve you well if you treat it well. Suggest cleaning/oiling every time you change a bobbin, every 8 hours of continuous use, or every six months if it is not in regular use.
Posted on Mar 25, 2015
    New Friend:
Hey cool, worked for me! I just inherited my mom's old Bernina a few months ago. I think she hadn't used it for awhile.
Posted on Dec 31, 2012
What model singer buttonhole attachment will fit a Bernina 807 minimatic machine. This question was asked but I can't find the answer.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this:
https://www.youtube.com/watch?v=JOImaKwv4fU
but you need to purchase a snap-on shank adapter for your Bernina, like this:
http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
Button hole MPG (good tutorial)
807 Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwidgJqA1rDRAhVU7WMKHbfsAfUQFggcMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja (pg 27-28)
Tutorial how to sew buttonholes with the BERNINA presser feet no 3 3A 3B...
Genuine Vintage Bernina Old Style Presser Foot 033 Manual Buttonhole eBay
Jan 07, 2017 | Singer Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
Have replaced cam gear on Bernina 830. Needle pendelum is fine on regular zig-zag stitch, but is out of sinc on the other decorative stitches..How can I fix this problem?
Its working maybe not timed anymore sometimes its the same way like a mode-select switch on the timed intake of a function on a videorecorder when its getting dirthy contacts it will function so that it worked in the wrong way outside the borders of the end of the circuit and can caused several damage or have only a missing link. but beware to take the problem that caused the problem out on this otherwise it is only for a short while suc6
SOLVED Bernina 830 service manual Sewing Machine
Dec 23, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Why the lever won't move from straight stitch to other stitches on my bernina 801?
thats a 50 year old machine...its seizing and needs oiling and service
Sep 17, 2014 | Sewing Machines
Where can I find an online user manual for Bernina Bernette 46
Hi Sheila,
I have this manual for you that might help your question. Hope it helps.
Bernina Bernette 46 Manuals
Apr 25, 2014 | Bernina Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Sewing Machine Problem
Check to see if the cam stack gear does not have a crack in it. The other problem is the cam engager lever is does not engage the cam stitches because it is gummy. To solve this, lift the lid and follow the lever to where it make contact, add a penetrant oil. More the lever back and forth as fast as you can and work the penetrating oil into the area. It should click back and forth and snap between the back and front V's. One is for the zig zag and straight stitches and the other is for all cam patterns. Once it is clicking and snapping back add regular oil. Thensew out your pattern stitches. If the machine binds then you could have a cracked cam stack gear and has to be change by a Bernina service center.
SewTechnologist
Apr 18, 2008 | Bernina Activa 130
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
3,204 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
