Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Polaris 500 xc backfiring through carbs, running on 1 cylinder
This sled is backfiring through carbs and it feels like its running on one cylinder. One plug is dark and one looks washed. I just put new gastank,headgaskets,basegaskets,cleaned carbs. Pistons look good and there isn't any blowby.The compression in each cylinder is 120.
  • Anonymous Feb 27, 2009
    My problem is with a 600 lqiuid cool and she is doing the same thing!We just after putting new oil seels in her and she is still backfireing!
  • Anonymous Mar 30, 2014
    got a 94 xlt snowmobile, got pto bearings done, and it took about two months so put engine in sled and wounld,t start , so cleaned carbs and pump , started but then stoped. plenty spark but gas is going straight threw to base . what is problem
  • 141 Answers
Timing or cam
Posted on Feb 15, 2009
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
What would be the cause or most likely cause of noticable hesitation on acceleration of 2002 polaris xc sp 500 with tps
I've owned many polaris snowmobiles and to me it sounds exactly as the current owner states. It probably needs the carbs thoroughly cleaned, taken out and apart. I would also get new plugs as well. I prefer ngk plugs for my sleds. If you've never done it there ate plenty of you tube videos on how to clean and adjust the carbs.
Dec 09, 2017 | Winter Sports
Harley downpipes glowing red
Could be running VERY rich causing ignition of the exhaust gases once the second cylinder is on its exhaust cycle. This would cause both flames out of the exhaust as well as the crappy performance. Pull the plugs and see if they're dark.
Clean the plugs
If the plugs look darkened you can use the A\F mixture screw on the carbs to lean out the mixture.
To tune like this.
Find both A\F mixture screws on both carburetors.
Find out which way to spin them to lean the mixture out (for me it was to tighten them).
Using 1\8th turn adjustments do one carb at a time until it runs better\stops backfiring.
Now that it's running decently go for a spin WITH NEW PLUGS, after a good little jaunt let the engine cool and pull the plugs, if they look white you need more fuel, if they look sooty you could need to lean out the mixture 'slightly'.
Feb 16, 2012 | Harley Davidson Motorcycles
I have a 95 Road King that isn't running right, it
Backfiring out of the exhaust is usually an ignition problem. Unburned fuel is getting into the exhaust system because it's not being ignited in the cylinder. When the engine fires on that cylinder again, it ignites the raw fuel in the exhaust causing the pop that people call a backfire. I'd investigate the ignition system. Connect a timing light to each of the spark plug wires if it has a single fire ignition or either of them if the ignition system is the stock dual fire. Start the engine and watch the timing light to tell if the engine is missing as the light will miss a flash.
Good Luck
Steve
Jun 05, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
I have an 89 ZX10 it sat for about 8 months when i fired it up it ran like a pig coughing & spluttering backfiring. I cleaned the carbies put in new plugs checked compressions 170 - 180 on all four....
You still have an obstruction in one or more carb. Start it cold and start feeling for a cold exhaust pipe. (That will be the bad cylinder) Be careful as they get hot very fast.
Apr 28, 2011 | 1989 kawasaki ZX 10
1999 XC SP 500 ,1,500 miles only----starts and runs - then at different occurences the sled will just die. SIt for awhile (minute of two) starts again and dies and then wait a few minutes, starts and...
WHEN THIS HAPPENS, CHECK FOR SPARK. IF IT HAS NO SPARK THAN IT IS AN ELECTRICAL FAULT. IF IT HAS SPARK IT COULD BE FUEL DELIVERY PROBLEM OR A INTERNAL ENGINE PROBLE.
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris xc 500 twin one cylinder not running right
DOES THE CYLINDER HAVE LOW COMPRESSION. IT SHOULD BE SOMEWHERE AROUNT 100-130 PSI AND NO MORE THAN 15% DIFFERENCE BETWEEN THE TWO CYLINDERS. IF IT IS LOW, A REBUILD IS GOING TO BE REQUIRED. IF IT IS OK THAN CHANGE THE PLUGS AND DO A CARB CLEANING AND SYNC THEM.
HOPE THIS HELPS
Dec 26, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 2001 polaris RMK 700. It seems to use a lot of gas. It is like it is running on 1.5 cylinders. It doesn't have alot of zip and is real sluggish when it is running. We have gone through the...
Certainly the carbs should be treated as a pair and so when one is suspected both should be checked. The cylinders will be unable to perform equally unless both carbs are tuned equally and synchronised at idle and at various throttle openings.
As part of the checking process it is important to ensure both cylinders are capable of performing equally. A compression test has limited use and a cylinder efficiency test is better. Injecting compressed air into the cylinder would prove the effectiveness of the valve seats and piston rings. A small amount of leakage of the inlet valve seat would make little difference to a compression test but it would make a great deal of difference to the way the cylinder performs.
Another important check is the valve clearances and also the ignition timing if it is adjustable. Some engines with twin ignition systems need to have the timing set for each cylinder.
Mar 15, 2017 | Polaris New Genuine Polaris Snowmobile...
I have a 2000 polaris indy 500, seems to lack power and when you let off after giving it alot of gas and then give it gas again it backfires thru the carbs. it really lacks power...
I WOULD DO I COMPRESSION CHECK ON THE CYLINDERS, THEY SHOULD BE SOMEWHERE AROUND 100-130 PSI WITH A DIFFERENCE OF NO MORE THAN 15% BETWEEN CYLINDERS
Dec 12, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
2,231 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
