Question about Logitech 967437-0403 Keyboard
CONTROL KEY IS USE AS A HOT KEY
WHEN I PRESS CONTROL KEY IT OPENS UP THE SEARCH AND WWW PAGE IT IS NOT FUNCTIONING AS IT USE TO BE LIKE SELECT ALL FILES AND FOLDERS ETC.
IS THERE ANYONE WHO CAN HELP ME TO TROUBLESHOOT MY CTRL KEY.
  • 51 Answers
Kkkkk. all you do is hold shift for 8 seconds and turn stickykeys of and if that no work hit shift 8 times or more and turn of hot keys or... talk to your dealer
Posted on Feb 11, 2009
I need a pin code for a Toshiba tv. Please
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Dec 17, 2017 | Toshiba Televison & Video
Tip
CD-DVD drive is not detecting/working
Click Start button, type Device Manager in the Start search box and hit enter key.
Device Manager window opens.
Expand Cd-Dvd Rom devices.
You will find Cd-Dvd driver listed here with yellow ! mark.
Right click on the driver and select uninstall.
It will get disappeared now.
Now minimize the Device Manager.
Click Start, type regedit in the start search box and hit enter key.
Registry editor opens.
Please locate then expand following subkeys :
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Now please select the following entry through cursor.
{4D36E965-E325-11CE-BFC1-08002BE10318}
Now look for UpperFilter or LowerFilter or both in the right pane.
Right click on UpperFilter and/or LowerFilter and delete them.
Press F5 key once and close the registry editor.
Maximize the Device manager now.
Click Action menu at top of Device Manager then click Scan for hardware changes.
It will reload the Cd-Dvd driver without yellow ! mark and the issue is resolved.
on Sep 16, 2011 | Computers & Internet
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    HL-DT-ST DVD RAM GSA-H20N ATA Device is not reading and writing CD. But reading and writing DVD. Firmware too updated. still not reading and writing cd. what would be the problem . plz send the...
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    Sep 18, 2011 | Computers & Internet
    Set clock
    Set the unit to STANDBY mode. Press and keep pressed the MENU button for about a second. Now with the control button on the right, select CLOCK ADJUST. Now press and keep pressed the control button for about a second. The clock display should be blinking now. Moving the control button up/down and left/right will set the hours/minutes.When done press the menu button once. You should now have a functioning clock. Here is a link to Kenwood support page:http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ select your model from the model drop down list, it's there. or send me your email and i will send you the PDF file myself. It is always a good idea to keep the manuals of all your equipment. dreamsystems
    Feb 11, 2011 | Kenwood Excelon KDC-X789 CD Player
    I am trying to get my philips universal remote to workcr with a sony dvd/vcr player..how do i do it?
    please go to the below website and select the model of your remote.
    An page opens in that you have REMOTE CONTROL CODE FINDER,click it
    Choose the device type and device make it gives the code for your remote.
    Then follow the procedure given below,
    1 Turn on the DVD ( The DVD should play ).
    2 Select DVD on the remote (= Press the device key for which you are programming the remote ) :
    keep the key pressed for 5 seconds until it blinks twice and then remains lit.
    3 Enter the given four-figure code for your brand , using the digit keys .
    – The DVD key will now blink twice and then remains lit.
    • If the DVD key blinks once , the code has not been entered properly or
    The wrong code has been entered. Start again from step 2.
    4 Press and hold the “ standby/power on” key and immediately release it when the TV
    switches off (standby).
    – This may take up to 30 seconds.
    5 Turn on the DVD and check if you can
    operate all needed functions on your DVD
    – Make sure the receiving device is able to respond and accept the desired command .
    6 Press the DVD key twice to exit setup mode and save your settings.
    – When no key is pressed for 2 minutes or more the remote control
    will exit setup mode automatically.
    • If the device does not respond at all or not to all of the key commands or if you cannot find
    the code for your brand, enter ‘0, 0, 0, 0’ in step 3 and continue with step 4.
    The remote control will now search the full database for a code that works with your DVD
    Full database search may take up to 15 minutes.
    thanx
    Jul 21, 2010 | Universal Remote Control Hampton Bay...
    Keys not working
    Try to unplug the keyboard, restarted the computer and reconnect the keyboard once the computer is fully restarted.
    Then go the Control Panel, double-click the keyboard icon. Select the Hardware tab and make sure that the "Standard 101/102 key or Microsoft Natural Keyboard" is highlighted or selected.
    Aug 17, 2009 | Logitech 967233 Keyboard
    Unlock codes Insignia NS-8PDVD
    You may have missed a step in the procedure try this one. This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
    Jan 16, 2009 | Insignia NS-8PDVD
    Logitech 967437-0403 Keyboard Logo
    121 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
