Question about E-Machines M5305 Notebook
Replacement DVD-ROM drive
I own an Emachine M6410 that is not recognizing discs. It has a virus that will not let me pull up Windows. When I went to recover the hard-drive the driver did not respond in the DVD-ROM drive. I am guessing that the drive has failed. A year ago I found replacement drives for the Emachine M6410 laptop but this year they seem to have gone the way of the dodo. Any advice on where I can get one or perhaps it might not be a bad drive after all?
  • brennon849 Apr 24, 2009
    I talked with my brother, who fixes computers for a living, and he said that it was my hard drive that was the problem. He gave me a replacement hard drive which I installed, however, my original 3-disc restore CDs that came with the computer still freeze in Symantec Ghost 7.5.0.33 when I try to restore my computer. When I install UBUNTU operating system it will install everything, though. Could something be wrong with the actual restore discs themselves?
  • E-Machines Master
  • 4,806 Answers
Hi there.
get hold of a boot cd or a windows install disk, set the boot options to boot from the cd drive, if the cd or dvd starts to boot and you get windows loading window then chances are that the lens on the drive is dirty and need cleaning, its also a possibility that the hard drive has bad sectors on it so setup can't write to the disk, hirens boot cd is a usefull tool to check for and recover bad sectors.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
My emachine does not load any dvd rom disc's it will read a cd rom disc but will not recognize the dvd's.model # w3107 2006 year
more then likely the DVD laser part of the drive has burned out, i have nearly the same model and had to replace mine a couple years ago!! This is a classic situation, the CDROM laser is still functional, but DVD is inop!!! New DVD-RW Drives about $20 on www.NewEgg.com and even cheaper on www.eBay.com for a decent DVD-ROM model!!! Easy fix too, just make sure you get the IDE style, or make even faster with SATA, if you have a SATA available on your system!!
Feb 20, 2011 | E-Machines W3107 (RBW3107) PC Desktop
Can you play PC DVD ROM on an emachines E4026 Desktop PC. because i just had a game brought for me & when i try to load it , the computer reads it as a blank disc Any help appreciated ...
Based on the one and only specs sheet I could find for this model of emachine, it does have a DVD-ROM drive. So in theory it can. Does the unit play DVD Movies? if yes then it should work, try rebooting and then putting the disc in again. I assume the disc is clean and scratch free as the game is new.
If the OS on your computer has ever been reinstalled, you may be missing the driver for the drive, in which case windows would treat it as a generic CD-ROM drive, and not be able to read DVDs, you can get the drivers for the drive from the emachines website if this is the case.
Dec 25, 2010 | E-Machines emachines (emachinees) CD-ROM...
My pc says my windows is in the trash
dude use ur recovery disc..if you didnt make one then you need to reinstall ur OS sorry bro but a recovery dvd from ur computer is needed to fix this! UR PROBLEM IS YOU HAVE A HARD DRIVE WITH A VIRUS IN IT. YOU NEED TO A DISC THE INSTALLS A UR OS { MEANING IF YOU HAVE XP HOME PRODUCT KEY THATS THE ONLY OS YOU CAN INSTALL ON UR COMOUTER} AND WHEN YOU DO THIS IT WARNS YOU ! HARD DRIVE WILL BE COMPLETELY ERASED! THIS ENSURES THAT NO VIRUS IS LEFT BEHIND! IF YIU HAVE TROUBLE WITH A WINDOWS DISC OR RECOVERY DISC MAKE SURE WHEN YOU START UP UR COMPUTER AND EITHER HIT f2 OR WHAT EVER UR PC SAYS ANDE CHANGE BOOT SQUENCE THE CD OR DVD ROM AND IT WILL LOAD THE DISC ON START UP! MINE HAS A OPTION F10 AND ALLOWS ME TO CHOSE WHAT TO BOOT FROM THAT TIME ONLY OTHERS YOU HAVE TO GO TO F2 AND FIND BOOT SQEUNCE AND CHANGE TO UR CD OR DVD ROM DRIVE!
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
E-Machines M5305 Notebook Logo
231 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
