Question about Philips DVDR77 DVD Recorder
No signal won't record
Set up completed according to the instructions.
  • 40 Answers
Hello.
1. The button on your remote or TV that you switch channel over to for watching DVD usally got 3 different modes, AV, Comosite and RGB, Have you tried to switch inbetween these modes by pressing the same button several times to switch inbetween the modes ?
2. If its connected to the TV via a scart cable make sure the connectors are fitted all the way into the socket on both TV and DVD. These connectors can be hard to get all the way in sometimes.
3. Some DVD Players have internal settings for the output mode if you go into the menu and settings on the DVD.
Make a note on what it was set to before changing
Hope this will help you with your problem.
Posted on Feb 11, 2009
Error: asio system overload 10011 and invalid input settings 10021
I am not sure what platform you are using or what software, but I would recomend unistalling the edirrol completely. Then re-dowload all the drivers and re-install them completely. Remove all traces from your recording software also before reinstalling.
Please give a bit more iformation on your setup if this is still a problem.
Best of luck
Oct 31, 2011 | Edirol UA-25 External Sound System
I have a 2002 honda accord when I push on the brake padel my turn signals or my 4 way flashers won't work. When I put on my lights my turn signals or my 4 way flashers won't work. Could you please...
First check the fuse in the fuse box for signal light, replace the fuse with similar value if it is busted. If the fuse is still intact the problem would be the flasher relay( small cylindrical aluminum ) that is already malfunctioning.
Hope that helps you out!
Aug 07, 2011 | 2002 Honda Accord
I need instructions to record from vhs video player to dvd recorder
Connect the vcr to the dvd recorder via scart. Set TV to your usual dvd channel and power on dvd. Power on vcr and scroll through input channels (AV etc) on dvd recorder until you find the signal from vcr. Prepare the recorder ready to record, then play the vcr and start the dvd to record.
Sep 20, 2010 | Televison & Video
WHEN I PRESET THE VCR TO RECORD MY SHOW LAST NIGHT 8:00PM IT WOULDNT WORK THE RECORD LIGHT DID NOT COME ON AT THAT TIME
There are a few things you must do in order to program a recording. One, you must make sure that the vcr clock is set. Two, the vcr must be set on the right date, as does the recording. Three, make sure that the daylight savings, AM/PM, etc. settings are saved accordingly. Also, if you have the operating manual for the vcr, you could check it for exact program instructions. I hope this helps, and I wish you the best of luck! Sincerely, Der Strom
Apr 13, 2010 | Philips Magnavox DVD/VCR Dual Player
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
Are there problems recording to a vcr when using a digital converter box?
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Oct 27, 2009 | Zenith VR4207HF VHS VCR
Humax 8000T not used for a while, now says ''no or bad signal'' and says no channels available when it searches.I tried resetting to default settings but still no joy. When I checked signal status it says...
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
Oct 24, 2009 | Humax Televison & Video
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
Setting Time & Date
press and hold the menu/disp for or longer until the hq flashes. press the minus button until the time flashes...then press play button. press +/- until the hour is set, then press the ff button and change the minutes, then ff to the date and change accordingly. When finished press play then stop.
Sep 04, 2008 | Olympus VN-2100PC Digital Voice Recorder
Philips DVDR77 DVD Recorder Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
