Question about Kenmore 63942 Dryer
Gas dryer burner turns on and off every minute. Why does it go o
Burner goes on for 10 seconds, then off for 30, then on for 10, off for 30, etc. Therre seems to be some switch or thermostat telling the burner to shut off. Does it need replacing?
    President:
  • 2,559 Answers
Flame sensor is dirty or bad and will need cleaning or replaced.
Please rate this a fixya
Posted on Feb 11, 2009
Burner lights for 10 min then goes off
replace the 2 solenoids on the gas valve will solve the problem
Aug 08, 2012 | Maytag SDG4606A Gas Dryer
My gas burner comes on and goes for about 30 seconds to a minute and then shuts off and then 30 seconds or so later will come back on
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 24, 2010 | Magic Chef CYG2000AWW Gas Dryer
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
Piezo goes off every 10 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Gas dryer does not get very hot.
the dryer dries after two or three tries
Dec 29, 2009 | Kenmore Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Kenmore 63942 Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
