Question about HP Compaq Presario SR1430NX (PS566AA) PC Desktop
Compaq Presario sr1000(sr1430NX) will not stay powered on
After power button is pushed initially it will run for about 30-40 sec and then shut down. Can go to F10 and go thru Recovery until HD is starting formatting then computer shuts down. Tried another power supply no luck, reseated memory,switch memory around, disconnected DVD drives,removed modem,disconnected HD and tried to boot to a Win xp OS disc only. But still powers down after about 10-15 secs after initial startup.
  • greg_wamsley Feb 11, 2009
    Cleaned cpu and heat sink,removed battery, case is open to allow for heat dissipations. No loose cables or connections. Have gone thru this machine numerous times. Have not tried a different SATA HD but did try a IDE HD attached to the DVD connections on MB (if this will work) without luck.
  • Peter Steiert
    Peter Steiert May 11, 2010
    The motherboard is probably failing, however I can't be certain. It is less likely as the computer shuts itself down so quickly, however it could also be a heat issue.
    Brigadier General:
  • 8,619 Answers
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Posted on Feb 11, 2009
  • HP Master
  • 4,806 Answers
Hi there
Check that the system fan is operating and clean all the dust from the fan blades and heat sync, also i would suggest clearing the cmosCompaq Presario sr1000(sr1430NX) will not stay pow - 8f8edd3.jpg. if there is no jumper take the battery out for 10 mins and remove all power.
Good luck and thanks for using Fixya!!
  • Lee Hodgson
    Lee Hodgson Feb 11, 2009
    Hi again
    You have done everything a tech would do in this situation, a couple of options left now is the bios is corrupt and needs reflashing or the processor itself is faulty, if its neither of these then its quite possibly the motherboard itself.
Where do the power supply plugs go on the inside of a compaq presario sr1000
WATCH OUT FOR ELECTRIC POWER.YOU HAVE TO BE MOORE SPECIFIC.
Jun 10, 2013 | Computers & Internet
HP Compaq Presario SR1430NX Powering On Issues...HELP!!??!??
If the power supply is "Fine" then it has to be your motherboard. Look for the capacitors around the board. They should have either a dished or flat top. If any are domed or have a powdery substance on them, they will need replacing. Or if you don't want to do this, replace the board.
Apr 26, 2013 | HP Compaq Presario SR1430NX (PS566AA) PC...
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
The beeping you are hearing is a beep code. Since their is no visual image a specific series of beeps is played and repeated to help pinpoint the problem. The beep you are describing, and it is hard for me to know for sure without hearing it is, sounds like a problem with your RAM.
First, try reseating the RAM. If you have multiple sticks of RAM remove them and reinsert them. To remove the RAM, push the tabs on both ends down and remove the stick of RAM.
Reinstall them by pushing the RAM firmly into the slot until the tabs click in place.
Try booting up again. If the same beep happens try removing all of the RAM except for 1 stick (if you have multiple sticks).
If you do not have multiple sticks, you may want purchase or borrow a stick of RAM to test your machine with to determine if your RAM is faulty.
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 01, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
Presario f750us, push power button it lights up and goes right back off
I have seen another Presario desktop with this problem, and it was dust in the front panel jamming the switch on. Pushing the switch turned the machine on, but because it stayed on, after 4-5 seconds the PC shut down again.
I had to remove the front panel and clean out all the dust, then lubricate the switch movement.
Dec 19, 2010 | HP Compaq Presario F500 F700 and G6000...
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
I have an old 2005 compaq presario SR1000. I also have a Dell flat panel 1704FPT. I have tried hooking it up to the compaq tower and it will come on for a few seconds then a message will show saying that...
Bring up the monitor menu. There should be a button on the monitor itself. Find the signal input, change from analog to digital (DVI-D). That should take care of it.
Jan 28, 2010 | Compaq Presario SR1000T (568657) PC...
Compaq Presario SR1000 Won't Turn On
The power on buttom might be it. Before doing anything else, check and fix the power ON button. I have a tower that gave me the same trouble. The Power On button somehow was out of place. Once I aligned it, the tower worked again. Good guess..! Good luck
Jun 14, 2009 | Compaq Presario SR1000T (568657) PC...
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
HP Compaq Presario SR1430NX (PS566AA) PC Desktop Logo
1,235 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
