Question about Frigidaire FEF336BC Electric Kitchen Range
Frigitaire gas range, elect. oven ..."or"..displayed and control
Went to turn oven ON ,
Noise and pad went blank, fuses in the fuse box downstairs went out.
Replugged but pad does not work
  • nook7477 Feb 24, 2009
    turned on oven to prheat and heard a bang, the whole pad went blank. checked the breakers in the box, it had tripped itself off,turned it back on, but the only thing works on the stove now is the burners.
    from at a lost (i need help)
  • Frigidaire Master
  • 3,361 Answers
Check all circuits in the range for a short to ground and correct the short..
Your electronic controlis fried.
Power surges are electronic controls worst enemy.
Replace your electrinic control.
Posted on Feb 21, 2009
Oven not working
http://www.geappliances.com/search/fast/infobase/10002629.htm Follow the driections here to see if they work I had the same problem and this fixed mine.
Jul 30, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
The electronic display went out on my gas range so I can not start the oven. I can still use the gas burners on the stove, but without the electrical panel I can not start the oven. I checked the wire...
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Dec 18, 2010 | Frigidaire FGFB75D Gas Kitchen Range
Kenmore GAS Range, model 970-334422, display/oven control went blank, light still works in oven.
it is very likely that the display may have gone bad. but before you buy a new one does it have any thing on it at all
Aug 19, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Electrics not working
sounds like the board on the b ack where the main cable goes in,this happend to mine,very cheap to fix
Nov 03, 2007 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
290 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
