Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher door leaks
Bosch model shu43c06uc/14 just put in new gaskets for bottom of door and the one that goes around where door shuts, door continues to leak, just like before i replaced the gaskets
  • andyneader Feb 11, 2009
    no the door started to leak, so i just replaced the gaskets, where is the striker adj located ??
    Scholar:
  • 86 Answers
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Posted on Feb 11, 2009
  • Kris Seymour Feb 15, 2009
    Hi, The striker is the piece that the outer door goes onto when it closes! It is in the middle of the door at the top... It is the piece on the machine side that you want to adjust..
    Good luck and tell me how you get on...........................
Model SHU66C02UC /14
never saw one with cotton pad . call a repairman
Jun 09, 2015 | Bosch Dishwashers
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Water leaks from the door of countertop model on
My older model had cheap plastic type rivets around the window. Of course they broke and water leaked out the window. I took the door apart and put in a new gasket the siliconed the heck out of it!
Put dishwasher on a counter or floor and put a nice thick phonebook under neath the opened door for support. Carefully replace window with gasket and a bead of silicone. Put enough weight on top to press it down and seal it. Leave for 24-48 hrs. I've replaced the window 3 times and this fix has lasted 2 years now. total cost about $10 and a little effort. make sure you use heat tolerant silicone.
Dec 22, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Bosch SHU4302 DW has a leak in the bottom left. I cleaned the gasket etc. but no luck. Slow leak drip by drip in the wash cycle. This model does not seem to have the steam vent that other Bosch models...
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Dec 18, 2009 | Bosch Dishwashers
Bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Bosch Dishwashers
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
Bosch Dishwasher door leaking at bottom, brand new.
Um rough to diagnose without seeing it but there should be a rubber gasket along the bottom of the door. And does the door panel hit the side of the tub when u shut the door? It shouldnt
Nov 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
527 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
