Question about Pride Mobility Products Celebrity X 3-Wheel Scooter w/ 40 AH Batteries & Charger + Flat Free Tires - Color Candy Apple Red
Mobility scooter can anyone out there tell me how to swap the hand lever controls around on a sovereign mobility scooter . lenny lovesit
Tranz Group Limited SH.
Tranz Group Limited SH., one of the "Top One Hundred Manufacturer and Wholesaler Enterprises" in China, was established in 1998. It is a high and new-technology enterprise focusing on researching and developing, producing and selling consumer extreme motor sport products.
After more than 10 years of development, Tranz Group has about 300 workers and has entered into six dominant industries, which cover: Mopeds Scooters and ATVs Quads, Pocket Bikes, Utility Vehicles, Dirt bikes, and Dune Buggies products. Our product series are: ATV, Motorcycle, Elderly Scooters, Mopeds, Generators, Mini choppers, Mobility Scooters, Golf Carts, Manufacturer. Most of them are for export and have been delivered to more than 30 countries and districts. We are experienced in motor sports products for a wide range of internationally renowned enterprises and famous motor sports stores. "Passion, Innovation and Commitment" is the philosophy Tranz Group staff has insisted on for 10 years and will lead Tranz Group to further success and progression.
For more of our products and company information, please visit our website fastglobalsupplier.com and contact us at 1-(718)-554-0292 any time. We are sincere to welcome all the guests and friends at home and abroad to visit us.
Posted on Mar 19, 2009
Hello sir i have scooter mobility pride 3 wheel i but new battery than 1 day after i wash scooter the scooter not drive gave beeb 7 time than stop now a lot beeb if you can please tell me what to do
hi, well that's a 70amp rhino controller, beeb seven normally amounts to a throttle pot (wig wag ) fault... i suggest you make sure there are no water around the connector plugs going into the controller , please remove one battery lead before proceeding..I do offer free controller testing and have swap out units if required for as little as £40...
Regards
Rob
Jan 31, 2016 | Pride Health & Beauty
My Go Go Elite Traveller Plus is not working. The freewheel lever is locked, but it is beeping 5 times, and the owner's manual says that # of beeps means it is not locked! Can anyone tell me w
Hi you need to check the switch located on the brake , this can stick fooling the controller into thinking the lever is in free-wheel when in fact it's in drive mode...
press the little switch in after spraying with WD40 or any contact cleaner...repeat this to make sure the little switch is releasing fully.
Regards
Rob
www.gewizrepairs.co.uk
Jan 02, 2015 | Pride Go Go Elite Traveller Plus HD 4...
Light is blinking a 7 fault code, what does this fault code mean.
According to the owner's manual for this scooter, flash code 7 indicates a speed control lever fault. This is the lever that you push to go forward and reverse. The lever is attached to a throttle potentiometer to control the speed of the scooter. The lever has to be in the middle or neutral position when the scooter is turned on, if not, you will get a 7 flash code. If the throttle potentiometer is damaged you will also get a flash code 7.
You can try to adjust the throttle pot or try manipulating the neutral position and turning the scooter on and off until the computer sees neutral. This is a potential work around and will cause the scooter to creep forward when running with hands off the throttle lever because there is no zero setting. I usually just replace the throttle potentiometer and this solves the problem. I hope this helps.
Oct 23, 2014 | Drive Medical Spitfire Travel 4-Wheel...
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
How can forward and reverse controls be switched for someone with only use of left hand?
hi , just swap over the two outside wires located on the throttle pot ...
Regards
Rob
Apr 28, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Can the foward and reverse be switched from left hand to right hand
hi, you have to expose the throttle pot that attached to the throttle lever , looking at the pot you see three wire connects, swap over the outside ones but leave the middle one alone. Regards GeWiz.
May 13, 2012 | Pride Value Line Revo Scooter 3 Wheel
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Jun 29, 2009 | Kitchen Appliances - Others
Reversing thumb controls
Your authorized Golden Technologies, Inc. dealer can reverse the thumb lever controls so that when you push on the “left” lever, your scooter will move in the forward direction, and pushing on the “right” lever will move your scooter in reverse.
If you don't want to go to a dealer, any mechanic who is willing can make this adjustment for y ou. hope this helps.
Feb 14, 2009 | Golden Technologies Companion II Travel...
Need to change mobility scooter controls back to right handed
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
Feb 10, 2009 | Pride Mobility Products Celebrity X...
Pride Mobility Products Celebrity X 3-Wheel Scooter w/ 40 AH Batteries & Charger + Flat Free Tires - Color Candy Apple Red Logo
408 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
