Question about Microsoft Office Professional 2007 Full Version for PC
Want to know which cell in a excel sheet contains formula
How to find automatically which cell in a sheet contains formulas
Leave me alone i dont know you i just found it but by any chance do you know how to unlock a selection in 2007 microsoft word sorry i said i dont know you in a mean do you except my apoligy yes or no please replie
Posted on Feb 11, 2009
  • Damondrummon Feb 11, 2009
    hi i'm anew and i dont knoe how too spaell any thing could you haelp meae pleese
Please help me to solve the circular reference in 2013 excel file which stop opening the file. Thank you
first start excel and click on formula tab -->Calculation options -->Manual
excel1-yi4l5i2224qkwob0czw2k0fe-5-0.pngNow open file, if asks for update formulae, say no.
Now select entire sheet, select formulas tab--> Error Checking -->Trace Error.
excel2-yi4l5i2224qkwob0czw2k0fe-5-2.png It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Apr 12, 2017 | Microsoft Excel for PC
Copy data that contains formula and paste it to a new sheet minus the formula: is this possible?
Sure is - depending on your version of Excel.
1) right click on the cell with the formula
2) go to where you want to paste the value - minue the formula
3) right click and select paste special
4) click values (as seen in image below)
and that's it done.
If this helped you, then please help me and vote kindly.
Oct 09, 2009 | Microsoft Excel for PC
Excel 2007
  1. Select all cells (either press Ctrl+A or click on the small upper left square on the edge of the worksheet)
  2. In the menu bar, go to Format - Cells
  3. In the popup menu that opens, click on the Protection tab (it should be the last one on the menu)
  4. Deselect the small box tagged Locked
  5. Click on OK. Now all your cells can be overwritten, regardless the protection status of the worksheet.
  6. Select only the cells containing formulas that you want to hide (If you need to perform multiple selection, you can press and hold down the Ctrl key, while clicking on each cell you want to select)
  7. In the menu bar, go to Format - Cells
  8. In the popup menu that opens, click on the Protection tab
  9. Tick the small box tagged Hidden and the Locked box as well. If you don’t tick the Locked box, other users of your worksheet would be able to overwrite the formula cells, without even knowing that they contain formulas (as they become invisible following this operation).
  10. Click on OK
  11. In the menu bar, go to Tools - Protection - Protect Sheet
  12. If you want, you can input a password for unlocking the worksheet. This will prevent others from unlocking it. If you don’t want to do that, leave the password field blank and press OK.
  13. Now click on one of your cells containing formulas and look at the formula bar. It should be empty, although the formula is still there. The cell would remain locked, but it would be automatically updated when changing the content of its precedents relating to the contained formula.
Jun 25, 2009 | Computers & Internet
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
Excel formulas
type in "=" and then go to the cell in the 2nd sheet and click on the cell that contains the value you want carried to sheet 1. Then drag copy the forumula in sheet 1 to all the cells you want it to relate to. Now, if you place a value in e.g. A1 of sheet 2, then that same value will appear in A1 of sheet 1.
Good luck.
Sep 13, 2008 | Microsoft Computers & Internet
Regarding Excel formulas
Yes, its possible by designing a formula in excel.
Aug 03, 2008 | Microsoft Windows XP Professional
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
How many formulas we can use at a time in Excel
That depends on which version of Excel you are using.
Excel 2003 supports up to 65,335 formulas
Excel 2007 has no limit.
you can communicate between the worksheets which are contained by one workbook (one excel-file).
Communicating between files cannot be done with formula's.
Apr 04, 2008 | Microsoft Excel for PC
Formaul
you have to use the reference Do you know how to use it
Mar 31, 2008 | Microsoft Excel for PC
Excel Coordinates don't show up in Formula Bar
Heyo. I have had this problem before too. This procedure prevents the cells that contain the formula from being edited.
  1. Select the range of cells whose formulas you want to hide. You can also select the entire sheet.
  2. On the Format menu, click Cells, and then click the Protection tab.
  3. Select the Hidden check box.
  4. Click OK.
  5. On the Tools menu, point to Protection, and then click Protect Sheet.
  6. Make sure the Protect worksheet and contents of locked cells check box is selected.
Good Luck!
Wayne
Dec 28, 2007 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
