Question about HP OfficeJet 6110 All-In-One InkJet Printer
Get message close cartridge access door
It appears the door is closed but if I had a manual I could tell better. The top will not shut all the way but I can't determine where the hang-up is.
  • 214 Answers
Here's a link for the manual to your printer, scroll down to product details & you can download it...
http://www.amazon.com/HP-OfficeJet-6110-All-in-One-Multifunction/dp/B00007HULQ
I hope this helps you. Good luck.
Posted on Feb 11, 2009
C4480 74xl
>Remove print cartridges, >Switch off the machine..>Remove power socket>Wait 10 to 15 mts, >Clean the cartridge & printer contacts. >Switch on the machine wait till message appears for the cartridges>Insert mono cartridge close the access door, check for the message>Insert color cartridge close the access door, check for the message> no error message.. diagnoses end> any error during the cartridge loading replace particular cartridge
Dec 27, 2011 | HP Photosmart C4480 All-In-One InkJet...
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
May 18, 2009 | Lexmark C533DN InkJet Printer
Displays Error Code 1203 - What is that? User Manual is lost.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
My printer dont want to print
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Error #1203
Error #1203
A 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please carry out the steps below the image to confirm that this is a cartridge failure rather than a hardware problem
  1. Make sure the All-In-One is powered on.
  6. Check the operator panel to see if the same error has returned or if a new message has appeared.
    7. Check the operator panel. If the 1203 error is displayed, this cartridge is the defective item.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
