Question about Hiro V.92 56K PCI DATA FAX VOICE MODEM WHQL (H50003)
Hardware conflict I am having a hardware conflict with this modem But I see no conflicts listed in device manager. I want to try to fix this.
  • SusanHanson Feb 13, 2009
    I go into control panel, then bring up phone modem options then go into the properties then to diagnostics and Query modem. the reply to the query is "The port that the modem is attached could not be opened. This may be the result of a hardware conflict. Check the device manager to verify all devises are functional." I have checked the device manager and no conflicts with the modem. I have one with the ethernet controller. but I don't think it is the problem. But it maybe. I can not seem to stop it from trying recognize the Ethernet even with the Ethernet card removed. Could it be part of the motherboard? I am confused. PLEASE HELP.
    Scholar:
  • 125 Answers
You might have your internal modem set to the same com port as your com ports that are on your motherboard. You can try to go into BIOS and disable all com ports OR you can try to configure your internal modem in windows to use com 3 or com 4. Remember, that if your computer does have com ports in the back, then is is probably set to the same address as your internal modem so something needs to be moved.
Posted on Mar 16, 2009
  • 139 Answers
How do u k now its an hardware conflict
Posted on Feb 11, 2009
Tip
You have just been struck by the Blue Screen of Death. 1 Hardware conflict The...
1 Hardware conflict
The number one reason why Windows crashes is hardware conflict. Each hardware device communicates to other devices through an interrupt request channel (IRQ). These are supposed to be unique for each device.
For example, a printer usually connects internally on IRQ 7. The keyboard usually uses IRQ 1 and the floppy disk drive IRQ 6. Each device will try to hog a single IRQ for itself.
If there are a lot of devices, or if they are not installed properly, two of them may end up sharing the same IRQ number. When the user tries to use both devices at the same time, a crash can happen. The way to check if your computer has a hardware conflict is through the following route:
* Start-Settings-Control Panel-System-Device Manager.
Often if a device has a problem a yellow '!' appears next to its description in the Device Manager. Highlight Computer (in the Device Manager) and press Properties to see the IRQ numbers used by your computer. If the IRQ number appears twice, two devices may be using it.
Sometimes a device might share an IRQ with something described as 'IRQ holder for PCI steering'. This can be ignored. The best way to fix this problem is to remove the problem device and reinstall it.
Sometimes you may have to find more recent drivers on the internet to make the device function properly. A good resource is www.driverguide.com. If the device is a soundcard, or a modem, it can often be fixed by moving it to a different slot on the motherboard (be careful about opening your computer, as you may void the warranty).
on Mar 04, 2010 | Computers & Internet
Tip
10 reasons why PCs crash-You must know tip 1
1 Hardware conflict
EROR Resource Conflict -PCI in slot 03
Any conflict has to be resolved in the device manager go to control panel then system then choose hardware find your device click on it see what resource it has then attempt a change.Most likely the conflict is a glich and can be resolved by changing the resource or removing the device causing the conflict
Mar 08, 2011 | Acer Aspire 5100 Notebook
IC VERIFY CREDIR CARD SOFTWARE WONT DIAL OUT AFTER SWAPING HD TO A NE PC. EXTERNAL MODEM WORKS FINE, SETTINGS ON ICVERIFY POINTS TO MODEM COM PORT. SOFTWARE WILL NOT DIAL OUT. aNY HELP?
Ok,
There's really only a few reasons this would fail beyond the COM settings. First, if the computer you're using has actual serial ports on the board and you're using a USB modem or if there are more than one serial ports it's possible you have either got the wrong COM assigned or that you have more than one trying to use COM 1. This will not cause conflicts with newer USB based devices but can when using actual UART chips on the motherboard or a mix of USB and UARTs.
Go into device manager and check for additional ports. Disable all COM ports except the actual modem and try again. If it still fails, check for DMA and IRQ conflicts. Do this by going into Start>All Programs>Accessories>System Tools>System Information.
Once open navigate to System Summary>Hardware Resources>Conflicts and Sharing.
Check for any conflicts with COM 1 and it's related DMA settings or anything sharing an IRQ with the modem. If you find any devices conflicting or sharing IRQ or DMA with the modem either disable the device or go into device manager, double click the offending device, click onto the resources page and find an alternate configuration that uses different IRQ/DMA that won't conflict. This will require a reboot for most devices.
Sorry my answer would be faster but I'm shaking almost a decade worth of dust and cobwebs out of my brain that have built up since the last time I even used a modem for ICVerify.
Hope this helps, lemme know how you make out,
chris
Dec 23, 2010 | Computers & Internet
I have a logitech web cam but every time I click on to start a vidoe call my computer freezes I have tried to un install and then re install but no luck
it seems like you may have a conflict,make sure it hasn't been installed twice in your hardware manager....uninstall all usb devices they will all reappear when you plug them back in...and make sure you always plug the device in the same usb port otherwise in will install itself again,that is when you will get a conflict. 3g modems are famous for that
Jul 13, 2009 | Logitech Webcam
Missing
Have the driver disk handy and let the computer re-detect the modem. If it doesn't find it, remove the modem from the slot it's in and insert into another slot. the re-detect if it doesn't see it on boot up. It the computer still doesn't fing the modem, you may have a bad modem.
May 27, 2009 | Arris (FMMOTV92PCI) Modem
Audio CD sound Prob
Various conditions may cause this problem. To troubleshoot, check the following:Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
Joystick port is not working
The audio card joystick port conflicts with another joystick port in the system. Disable the audio card joystick port, and use the system’s joystick port.
The joystick drivers, MSJSTICK.DRV and VJOYD.VXD, may not be installed. Uninstall the joystick, then reinstall to load the drivers. The drivers should come with the driver CD or floppy diskette with your sound card.
Computer hangs or restarts during installation
A hardware conflict may cause the computer to hang or restart during the installation procedure. Check the following to resolve the conflict:
A hardware conflict with another device in your system.
Previously installed sound card hardware or software needs to be removed.
The audio card is not seated in the slot properly.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices.
Resolving hardware conflicts
Hardware conflicts occur when two or more devices contend for the same resources. Conflicts between your audio card and another device may occur regarding the I/O address, IRQ line, or DMA channel:
Right-click the My Computer icon on your desktop, and select Properties. The System Properties dialog appears.
Click the Device Manager tab. In the Device Manager, a plus sign(+) represents an expandable list of items. A minus sign (-) represents an expanded list. A circled exclamation mark denotes a conflict.
Double-click Sound, video, game controllers. A list of multimedia devices appears.
Select your audio card.
Choose the Propertis button.
Click the Resources tab.
Uncheck the Use automatic settings option.
Change "Settings based on:" if alternate settings are available.
Determine the conflict by reviewing the "Conflicting device list".
Select the conflicting item in the "Resource Settings" list.
Click the Change Settings button.
Use the mouse to select a new setting.
Select OK to close each of the properties windows, and restart your computer.
Audio card is not automatically detected
To manually configure your audio card for Windows 95/98:
Click "Start" on the taskbar, and select Settings from the Start menu.
Select Control Panel. The Control Panel group appears.
Double-click the Add New Hardware icon. The Add New Hardware Wizard dialog appears.
Select Next to continue.
Choose Yes to have Windows search for new hardware, then select Next
Select Finish, and follow the prompts to complete the new hardware installation.
CD does not automatically run when you insert it in the drive
To enable the "Audio insert notification" feature:
Click the Device Manager tab. A list of devices appears.
Double-click CD-ROM, and select your CD-ROM drive.
Choose the Properties button. The CD-ROM drive properties dialog appears.
Choose the Settings tab.
Click the "Auto insert notification" option to enable.
Select OK until all Properties dialogs are closed, and restart Windows for the changes to take effect.
No sound is heard from speakers
Verify the following:
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.
Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).
Ensure a hardware conflict does not exist between your audio card and another device in your system.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
If you are experiencing no sound only during audio CD playback, see "No sound is heard from audio (music) CDs" above.
Static sounds are heard in wave files
Check to see if the static sounds are heard in all wave files. If the difficulty occurs only with certain games, refer to the software manufacturer’s documentation. To troubleshoot static sounds heard in all wave files:
Try different resource settings for the audio card, or set the card to use low DMA.
Move the audio card to another PCI slot. Feedback from the power supply or another device may be responsible.
Oct 19, 2008 | Computers & Internet
DSL Connection
Are you trying to connect wirelessly or connecting directly to the modem? Have you added any new software or hardware within those past 3 days? There may be a conflict if you installed something new. For hardware - check Device Manager for any yellow icons for conflicts. if you installed software, delete it and see if that solves your problem. Remember to back up anything that is important from new software that you recently installed.
Aug 17, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Hot keys are not working on my Asus laptop
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
This is because of
The Human Interface Device (HID) is not configured to wake the computer when you press a key on the keyboard or mouse.
RESOLUTION
Use Device Manager to troubleshoot possible hardware configuration problems on your computer
In Device Manager, look for marked problems with devices. If there is a problem with a device, it is listed in the hardware tree under Computer.
Additionally, the problem device has a symbol that indicates the type of problem, for example a black exclamation point (!) on a yellow field indicates the device is in a problem state. Note that a device that is in a problem state can function.
A red X indicates a disabled device. A disabled device is a device that is physically present in the computer and is consuming resources, but does not have a protected-mode driver loaded.
A blue i on a white field on a device resource, in Computer Properties, indicates that the Use Automatic Settings feature is not selected for the device and that the resource was manually selected. Note that this does not indicate a problem or disabled state.
At the top of the property sheet, there is a description of the device. When you click the Resource tab, the window in the middle of the tab indicates which resource types are available for the selected device.
The list box at the bottom contains a Conflicting Device list. This list indicates a conflict with an error code. If any devices are listed as having a conflict, disable the devices in Device Manager. To do so, follow these steps:
1. Double-click the branch that contains the device that you want to disable, click the device, and then click Properties.
2. On the General tab, click to select the Disable In This Hardware Profile check box, and then click OK.
3. Restart your computer
If no devices are listed as having a conflict, follow these steps to disable devices in Device Manager:
1. Click Start, and then click Control Panel.
2. On the Hardware tab, double-click System, and then click Device Manager.
3. On the Device Manager tab, disable all devices under the following branches:
• Display adapters
• Floppy disk controllers
• Hard disk controllers
• Keyboard
• Mouse
• Network adapters
• Ports
• PCMCIA socket
• SCSI controllers
• Sound, video, and game controllers
To disable a device in Device Manager, follow these steps:
a. Double-click the branch that contains the device that you want to disable, click the device, and then click Properties.
b. On the General tab, click to select the Disable In This Hardware Profile check box , and then click OK.
c. Restart your computer.
4. If the problem is resolved, enable the devices that you disabled in step 3, and then verify that no devices are conflicting.
Note Enable devices in the following order:
• COM ports
• Other devices
To enable a device and look for possible conflicts, follow these steps:
a. Double-click the branch that contains the device that you want to enable, click the device, and then click Properties.
b. On the General tab, click to clear the Disable In This Hardware Profile check box.
c. Click the Resources tab, and then verify that there are no conflicts listed under the Conflicting Device List.
Note that the Resources tab does not appear for each device.
d. Click OK, and then restart your computer.
If this resolves the issue, contact the manufacturer to update the device driver. for the keyboard
Aug 14, 2008 | Computers & Internet
Hiro V.92 56K PCI DATA FAX VOICE MODEM WHQL (H50003) Logo
696 people viewed this question
Top Hiro Computers & Internet Experts
Prashant M
Prashant M
J D Wright
Are you a Hiro Computer and Internet Expert? Answer questions, earn points and help others
