Question about Janome 1600P-DB Mechanical Sewing Machine
TD init error 6500p
I've had machine since 2003 and this is the first time I've seen this .I was just sewing- not doing anything unusual
HOW DO I FIX A FM PHASE ERROR ON MY JANOME 6500 MEMORY CRAFT
Check your Feed dog switch for raised or lowered positioning and reengage to either setting and rotate the hand wheel to reengage the gears properly.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | Janome Memorycraft 6500P Computerized...
How to time memory craft 7000
your manual should have directions if you don't have please us your search engine on your computer put in model + name+ number + manual + free
Jul 03, 2014 | Janome Memorycraft 6500P Computerized...
My Janome 6500p is having bobbin issues
here are my suggestions
1. when your sewing check to see if the thread is coming off the thead take up lever,, I've had this to happen to me & it can jam a sewing machine up
2. it's possible that the bobbin case is worn & needs to be replaced
3.also check your top tension
4. try rethreading the machine top thread & bobbin
Feb 06, 2012 | Janome Sewing Machines
My footup and footdown button is stuck and I keep getting an E1 error on the screen. Do I need to take it in for repair or is there something I can do to fix it? Machine will not sew because of the error...
Turn the machine off first and unplug.
If you've got a manual, look up the page for trouble shooting, this error message may be listed iwth a solution. I'd also suggest that you remove and clean out the bobbin holder. This is the little black piece you put the bobbin into. It has possibly dislodged if you've had a jam up. You will need to unscrew the two screws holding the needle plate down, take out the needle and pressure foot to give yourself some room too. Put the bobbin holder back into position lining up the red markings on the holder and the stopper, your manual should show images of this.
Once its all back together, turn on and hopefully it will reset to normal mode.
If you've done all this and the error message won't stop showing, then yes, you'll need to take it in for a service.
Jul 20, 2011 | Janome Memorycraft 6500P Computerized...
Need a new bobbin holder with red dot and cant find part #. have a memory craft 6500p. the red dot denotes the tension.
Try SewVac Direct....they are usually very helpful. I have purchased from them, they are very reliable.
http://www.sewvacdirect.com/
Feb 15, 2011 | Janome Memorycraft 6500P Computerized...
Janome 1600P-DB Mechanical Sewing Machine Logo
125 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
