Question about GE WHRE5260E Top Load Washer
Timer pull button on my wjxr2080t2 broke
Anyhow I have the parts but what are the steps to assembly it?
    President:
  • 1,902 Answers
Remove the top cover behind the knobs. Two screws up top and 4 to 6 screws on the back. Once the back panel is removed then there are two screws holding on the knobs, remove the bad knobs and put the new one in the bad ones place. Forgot to tell you, make sure power is unplugged. Sure you knew that but just being safe
Posted on Feb 11, 2009
The button broke on the parking brake & the spring came out. Brake still works if you put spring in and pull up brake and hold spring down.
You'll have to replace the whole assembly. You'll have to remove the console to get it out. It will screws/bolts in the rear, in the box, under cup holder pads, on the sides, and up front. depends on your vehicle where the bolts are. This is every where I have found them.
May 29, 2016 | Cars & Trucks
Dial stops turning leaving heat on. How can I stop this happening?
It's your timer thats faulty due to wear and tear.140.jpg this part is available from catering parts and should look like item pictured. Fitting part is simple for any half competent D.I.Y enthuiast requiring a posi screw and a flathead screwdriver(Any flatblade will do).Step1.Remove all six retaining screws at base of toaster four are holding the feet and a couple more holding the plate.You will see the back of the timer assembly.Step 2.Using the flat screwdriver or blade gently lever off timer dial which will expose the dial spindle and also 2 retaining screws which holds the timer assembly in place.Remove these screws with your posi screwdriver.Make a note of terminal wires to the timer unit as these will all have to be removed and put back unto your new timer unit.Step 3 relace all wires as they were on faulty unit and a re-assemble toaster.This should definately solve your problem.Happy toasting and don't forget take your time and get it right keep all your screws as they will probably have to be re-used as replacement units some times come without screws so old screws may have to be used.Good luck
Oct 03, 2010 | Dualit 40352 4Slice Toaster
How do I adjust the headlights on a 2002 buick Century?
  1. Step 1 Purchase a replacement bulb from an auto parts department or auto parts store. The bulb number is 4157NAK. You also can check the parts book or ask store employee for assistance.
  2. Step 2 Open the hood of the vehicle. The hood release handle is located under the dash on the left side of the vehicle. Once you discharge it, you must free the second hood release under the hood of the vehicle in the center. Move it to the right and lift the hood.
  3. Step 3 Locate two headlamp retainers (clamps) holding the headlamp in place. Pull up to remove them to discharge the tabs on the assembly.
  4. Step 4 Detach the power to the headlamp. Now you can easily remove the assembly out of its position.
  5. Step 5 Take off the rubber cover located in back of the turn signal light. This will allow access to the bulb socket.
  6. Step 6 Turn the light socket counterclockwise to remove it from the assembly.
  7. Step 7 Remove the old bulb by holding the bottom of it and pulling it gently up. Replace with new bulb.
  8. Step 8 Once you have replaced the bulb, put the light socket back in the assembly and turn it clockwise to secure it.
  9. Step 9 Replace the rubber covering on the back of the headlamp assembly.
  10. Step 10 Put the headlamp assembly back in place by sliding it in the slot and attach the power supply.
  11. Step 11 Replace the retainer clamps to hold the headlight assembly in place and close the hood of the vehicle.
Jun 01, 2010 | 2002 Buick LeSabre
Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Apr 09, 2009 | Frigidaire FWS833A Top Load Washer
Driver's side electric windows won't work
TRY E-BAY MAY PICK UP A REGULATOR CHEAP,CAN YOU NOT DRILL AND PIN IT FOR STRENGH PLUS USE THE GLUE
Apr 02, 2009 | 2004 Audi A4
Digital key pad is locked up on 8 minute spin and fluff, Ive tried unplugging and plugging back in. I have a calapsyo, its about 5 yrs old
HI
Oct 07, 2008 | Whirlpool Washing Machines
Zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
thank u.......................
Sep 12, 2008 | Zanussi ZWF1430W Front Load Washer
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
GE WHRE5260E Top Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
