Question about SanDisk Sansa Clip MP3 Player
Sansa clip wont turn on
I turned my sansa clip off, the next day that i wanted to turn it on it wont turn on at all!
  • 3 more comments
  • Anonymous Feb 12, 2009
    I HAD THE SAME PROBLEM TOO. I HELD THE ON/OFF BUTTON DOWN FOR 20 SECONDS TO RESET IT AND NOW ITS ON BUT WILL NOT CHARGE.
  • Anonymous Feb 16, 2009
    The sansa clip will worked when connected to a computer or charger, otherwise it appears dead.
  • Anonymous Feb 17, 2009
    i cant
  • manderson94 Feb 26, 2009
    i have the same problem my 2gb clip will turn on for the computer but when i try 2 it will not turn on.
  • vampyro0414 Feb 27, 2009
    i just got a clip and it wont turn on it worked for about a week and took charge but all of the sudden it wont charge or turn on and nothing has happen to it to cause this what should i do?
How do you get rid of a virus on your mp3player Sandisk??
Posted on Feb 16, 2009
  • 8,596 Answers
Make sure the hold/lock switch is not accidentally engaged
Posted on Feb 13, 2009
When I turn on my SanDisk Sansa Clip MP3 Player all it has on it is record and ready, I used to have a bunch of music on it and I don't know what I did , I did try to download a book once,I think I did...
  • First you could try to RESET the Sansa Clip as next:
1. Turn the player on (shortly switch the power switch up)
2. Slide and hold the power switch up for 15-20 seconds
3. Release the power switch
The reset is completed
4. Shortly slide the power switch up
Check if the player functions normally again.
  • When the reset does NOT help next steps will be required:
1. Put the player in MSC mode: this way a computer recognizes the player as a removable disk.
How to put the Sansa Clip in MSC mode:
1.1 Turn device OFF.
1.2 Slide the Hold switch down to Lock (orange color showing).
1.3 Press and hold the center button while connecting the device to the PC.
2. Backup the media content on the player to the computer.
Connect the player to the computer and backup the files to the PC,
exploring "My Computer" in the removable disk.
3. Perform a firmware reinstallation / firmware update.
Use next link for updating the Clip's firmware:
http://kb.sandisk.com/app/answers/detail/a_id/300/related/1
The Sansa Firmware Updater execute file is mentioned as installer
for getting the matching updates for the Sansa Clip.
Direct to the Sansa Firmware Updater execute file with next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
Right click the link above and select "Save Target As..." for saving the
installer to a location on the computer.
Double click the execute file after the download has completed to run it.
Sansa Clip manual
When this helped, I'd appreciate your vote.
In case you need more help, just add a comment.
Jan 02, 2010 | SanDisk Sansa Clip MP3 Player
Doesnt turn on
THis happen to me to then i turned on i deleted all my song then it turn on idk if u want to try this
May 23, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Will not turn on
Maybe it's wrecked and wont work any more. Try ask someone to get it fixed for you
Feb 24, 2009 | SanDisk Sansa Clip MP3 Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
Sansa wont turn on.
The clip on the back comes off, and you can remove, reinsert the battery.
Jun 30, 2008 | SanDisk Sansa Clip MP3 Player
It froze
Sansa Clip Player has some problem. I tried 4 sansa clip players (I purchased at Best Buy for Thanksgiving), and none of them work. Dont even try to exchange them, just return them back.
Oct 24, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
152 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
