Question about MSI 661FM-3 (661FM3L) Motherboard
Msi 661fm3-v when i seyup anew windows i cant't do it becoz the windows didn't find any driver to setup it and be noticted that my hard disk is sata type
  • MSI Master
  • 4,806 Answers
Hi there
If its XP you are trying to install then you will have to get extra drivers for setup to recognize the SATA drive.
The drivers you need will be in the "matrix storage manager" you can download this from Microsofts download site.
Once download read the instructions carefully as you will either have to create a floppy disk or a bootable USB drive with the SATA drivers on them.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
I need sata driver for 661fm3-v msi motherboard
which sata driver for the cd/dvd drive ot sata hard drive
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 16, 2011 | MSI 661FM3-V Motherboard
Hi.I want to format my hard disk and install windows xp home edition. But it end up by saying it cant detect my hard disk. im using MSI km400 with sata.
Windows XP comes in 2 'flavors', one being the OEM or 'Full' version, and the other is the 'upgrade' version. The Full version will setup and format the hard disk, applying the boot track. The Upgrade version expects to see the boot track there, and will not proceed further. You may need a utility like Seagate Diskwizard to setup the hard drive for installation. That program can be downloaded from Seagate's website.
Apr 02, 2010 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
I have a wd sata hard disk and i cant setup windows xp on it, it the monitor says ..... " windows can not find any hard disk instal into your motherboard " i need to solve this problem please thank you
Windows XP didn't have support for sata drives. You will need to load the driver by pressing F6 when you start the Windows setup. You will see the message
Press F6 to load 3rd party drivers at the bottom of the screen when Windows is installing.
Apr 06, 2009 | MSI Computers & Internet
I need to connect h.d sata with motherboard msi 661fm3-v
I assume you mean how.
Reakky sata is easy, Just clip on to the right port and plug power. Your system shoud be able to autodetect it. Just make sure that you go into th bios and make sure that sata is enabled.
Mar 17, 2009 | MSI 661FM3-V Motherboard
MY msi 7082 cant read HDD 40GB and above whY>?
Your board specifications are here - http://www.msicomputer.com/product/p_spec.asp?model=661FM3-L&class=mb
This sounds like a memory timing issue based on the caution from the MSI page. There is no reason the board itself should have a problem with that size hard drive. Have you reset the bios to factory default and tried the various compatibility settings available in the bios?
Dec 26, 2008 | MSI 7082-010 (661FM3-V) P4 LGA775/SiS...
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
QUESTION FOR SOLVING
You must press F6 during the XP setup when it asks you for a third party disk controller driver. You get one chance to do this, near the beginning of the setup. You must have the SATA driver available an a drive you can read during setup, such as a floppy disk. The driver should have come with the motherboard, otherwise you may have to download it.
Jun 16, 2008 | MSI : 661FM-L P4 SIS661FX FSB800...
Windows Setup cant find hard disk ?????????????
Does the BIOS on your system see the drive and show it's model information? Is this the only drive on the system? If the answer is yes for both, then you can download free utilities from the web to wipe the drive clean. This will result in the loss of all existing data on your drive. You can search for "Wipe Disk" and will get several hits for free software. Once you have cleaned the drive, try instlling XP. If the BIOS does not see your drive, the XP can't see it. You may want to try other SATA ports on your motherboard, or try changing the IDE configuration in the BIOS. Let me know if this works.
Aug 29, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
MSI 661FM-3 (661FM3L) Motherboard Logo
91 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
