Question about KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher
Heating circuit and thermostat design
I am building a drying cabinet for meat products and need to install a heater at the base with a thermostat to control the temperature. Any advice on how to wire it? The cabinet will have a fan circulating the air all the time...
Thanks...
  • 257 Answers
Hi, You need a thermostat with a remote sensor that should be about the same position as the middle rack in the cabinet. Yes, have the circulating fan run constantly on a separate switch or on a rotary in the second position and the fan/heater in the third position as off, fan on, fan/heater on. I would also wire in an indicator light or two as well as some way to monitor temp/humidity so that you would have a positive indication that things were running, the idea being so that you open the cabinet as little as possible. By the way this works great for fruit with just the fan. Good Luck!
Posted on Feb 11, 2009
How do I set timing to dry clothes for 1 hour?
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Mar 03, 2015 | Dryers
Increase drying time in co-op dryer
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Feb 14, 2015 | Dryers
My Maytag bravo Dryer is not drying my clothes correctly. The timer on the dryer keeps going up higher indicting it needs more time to dry?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Oct 13, 2014 | Dryers
Kenmore elite quietpak 9 he4 cuts off after drying clothes for a while. clothes are still damp
GOD IS STILL GOOD !!!!
Sep 27, 2014 | Dryers
How do I repair an Amana dryer not heating?
overheating.
GOD IS still GOOD !!!!
Sep 05, 2014 | Amana Dryers
Why wont my dryer dry my clothes?
Aug 12, 2014 | Kenmore Dryers
What is wrong if the dryer doesn't stay hot?
May 27, 2014 | Kenmore Dryers
Dryer cuts off during drying cycle
May 24, 2014 | Kenmore Dryers
The dryer is not drying. The drying temperature
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 19, 2010 | Kenmore 500 6952 Dryer
Not drying
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like an operating heater thermostat. It is usually on the area next to the heater but not on the heater. Sounds like its opening to early. But it could also be bad air flow causing a safety to open. Could also be the timer not completing the heat circuit to the correct place on the heating element. You would need a wire diagram to see if you have more than 1 operating thermostat. and a timer circuit diagram if it has more than 1 heat setting. If you read diagrams these will explain themselves.
If you feel confident here are the main things to do on checking for no heat Electric Heating Dryer:
1 Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most dryer models).
If you have 220v there the heater element is out.
2 If you don't have 220v on the terminals of the heater the problem is in the controls.
The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating thermostat(s), are all suspect and have to be eliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow. A kinked Dryer vent hose, lint, and plugged up fan circulator on the motor, or if yours has little holes in the inside cabinet where the air is taken to be heated and recirculated, these can get clogged with lint also and cause a problem are the 4 main causes of low air flow..
Hope this helps and please rate me accordingly Thank you and good luck.
Mar 11, 2009 | LG DLE2532W Electric Dryer
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
102 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
