Question about Intel Motherboard
No beep i had 915glvg intel mother board i had recently issued the problem no beep and no display and under cpu it is heating... ram ok smps ok mointor ok cpu ok
  • Intel Master
  • 4,806 Answers
Hi there
It could be a memory issue, try different memory, if you still get nothing the bios is probably corrupt rendering the board useless.
Good luck and thanks for using Fixya!!
Posted on Feb 11, 2009
MY COMPUTER IS NO DISPLAY, POWER OF SMPS & CPU FAN IS RUNNING , RAM IS OK, MY BOARD IS INTEL 845 GVSR
sounds like you may have an issue with your display driver or grahics card. try opening the computer and re-seating all of the hardware.
unfortunately this used to happen to me and its basically a trial and error fix.
Does the bios make a beeping noise when started?
Jun 11, 2011 | Computers & Internet
Display probelm
After reading your issue,i am sure that there is problem with your motherboard.
as you cannot see anything on screen and you get power,that means your motherboard is faulty
so just get your motherboard replaced and it will be fine as before
Thanks
Jul 28, 2010 | Intel Desktop Board D845WN Motherboard
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
No display, i have already change my ram, processor, power supply but no result if i pull my ram replay ram beep from motherboard
no display is basically ram issue but condition that mother give u beep noise,
refix RAM proprely, chaque SMPS , PROCCESSOR,HARD DISK, Fixed togethar again ok resolve issue.
Mar 17, 2010 | Intel 845GEBV2 Motherboard
Mother Board
if it has 2 video cards or had 2 might be disabled in bios. if not and it does not boot at all then it could be CPU Powersupply or RAM, i would start with removing RAM and see if it beeps if it does Power Supply migh be ok, put one stick of RAM back in snd see if it boots swap RAM Slots and stic around to make sure its not a RAM Problem. if still no video and just spinning fans its Trial anf error of the CPU and Power Supply i know it **** but if you have a PoSupply tester that would rule that out. if you are savy enough to remove CPU look for burnning and smell for Burn. Good Luck
Feb 24, 2010 | Intel Motherboard
Intel D945GCNL Board No display
Dear user, this problem can be coused by many things.
1, The memory you have installed is not compatible with your system.
2, Power supply failure.
3, Contact issue between the socket and the module.
Try thease:
Take a brush and clean the sockets.
Power on your computer without the memory modules, if you hear beep it could be a health signal :D.
Power off the system.
Clean your memory module pins with alachol or other cleaner liquid.
Wail till it dry, inster it back to the socket and move a little ud and down to catch ancontact.
Power on and now shold be work fine.
If this ain't works. Try other brand of memory, kingmax or kingston. They usually shipps with 99 of good modules from 100.
Good luck.
Mar 22, 2009 | Intel D945GCL Motherboard
No beep
it sounds like a conflick with something you are using, try some different memory, if you are using the ram stitch the memory around put the first chip last and the last chip set first, are you using the on board vedio or you using a card, same with the sound, if the mother board has these option on them than try and get them running and than switch over to the new cards configuration, if you start having problems than do one install at a time until you find out which one is giving you the most problem, i think i would start with the sound first than the vedio, than the high speed internet connection and so on
rod gandy
Jan 29, 2009 | Intel Motherboard
Intel motherboard
You may either need to replace your cpu or replace your motherboard. I couldnt really tell you which one without looking at it but It will most likerly be one of them. Thanks
Onlinepc-fix
Apr 21, 2008 | Intel Desktop Board RC440BX...
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Motherboard Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
