Question about Sony SDM-HS75P/S 17" LCD Monitor
No power Black screen, look like power supply
  • 1 more comment
  • lludmill Mar 25, 2009
    could you specified where exsactly is this small fuse
  • wtodd2 Apr 29, 2009
    the monitor screen randomly goes off and then comes back on.
    When this happens, the power light also goes off and on. When it goes off, it is only off for a few seconds, then comes back on??
  • kyriacospan
    kyriacospan Nov 16, 2012
    i have a problem like this wtodd2 ... pls tell me what is the problem and how can i fix it ... thank you
SDM HS75P model has no fuse. I recently had the opportunity to open one. It was a long shot in the dark having without any documentation or service manual.
Need more details about your problem. Does the power light come on and if so, what color. If not then first thing to do is to check the power cord. If you're not a tech then ask someone to repair it for you.
Posted on Apr 03, 2009
    Sergeant:
    Champion:
  • 285 Answers
Could be the power supply like you said and the most obvious things to check when its open is the small fuse on the power supply or any capacitors which are buldging which are faulty.
This is for lcd monitors which have a built in power supply or if you dont know they use the kettle type lead =].
Posted on Feb 13, 2009
Why does the screen go black but yet still sound?
Moat likely it is because your power supply is defective and it is not producing tv sufficient voltage to power the backlight. I would replace the power supply.
Jun 29, 2014 | Samsung LN-S4041D 40 in. LCD HDTV
Dell STUDIO 1537 black screen on first boot up ??
The inverter maybe faulty, it supplies high voltage to the CCFL lamp and would cause the screen to be black.
Since it was just repaired, I suggest you return it to Dell to have it repaired under warranty.
May 09, 2012 | Dell Studio 1537 Notebook
Power light on screen black GE tx47f035
Power supply needs to be checked--voltages that come into it and out to begin with.
Also if open examine the power supply for puffed up on top caps.
Apr 26, 2012 | Televison & Video
My hp monitor is totally black it was working last night. i tried to unplug and replug it in and it came on for a few seconds then went black again
A lot of time people have the impression that the monitor is not working when in fact the computer is not booting its lighting up but nothing else so its stays on a black screen.
One way to know is by opening your speakers or plugging head phones, if you hear windows open or any windows sound the problem is the screen.
You can also unplug the screen from the pc and turn the screen on most of the time the screen while show a disconnected warning on the screen if that comes up the computer is defective.
Oct 29, 2010 | HP Computers & Internet
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
When you star it is black screen and stay black
If nothing is happening, it is related to the power. Make sure that you are using a electrical outlet that is working (use a light to test). Unplug the power cord from the back of the computer, as well as from the wall socket, and then plug it back in with authority... making sure it has a good connection on both ends. You may also use another power cord (but rarely would be the cause of the problem). If there is no action from the power supply when you press the on button, then the problem must be with the power button or the power supply. I would lay odds that it is the power supply, replacement should cost about $30.
Hope this helps. Best Regads, -md
Nov 11, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Static noise and black screen
hi..
Based on what you are stating, could be power supply problem. Try replacing power supply adapter that Dell supplies. Go on Dell support page using your computer number and you can see if there are any manufacturers recall on the computer or the power supply...
Aug 18, 2009 | Dell Inspiron 6400 Notebook
Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Feb 21, 2009 | Televison & Video
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Sony SDM-HS75P/S 17" LCD Monitor Logo
919 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
