Question about SanDisk Sansa e200 MP3 Player
Cracked screen the screen is cracked and there is ink so i can`t see which songs i'm playing and the back is missing
  • Anonymous Feb 11, 2009
    i stepped on mine(on accidenty and can hardly see the screen at all.
    Problem Solver:
  • 11 Answers
It's broke. No question about it. You can either upgrade, or if you're not scared of hacking into the mp3 you can use my solution for when I break the screen on my e280. Disclaimer, this can easily cause damage, nothing is guaranteed when you do this and it in in no way risk free. I am not responsible. When I break my screen ( which I've done 4 times now) I get a used mp3 off ebay ( I've found that any e200 series will work. However, if you get/have an R version the end result- which I will from now on call frankenp3- may/ may not be an R version, but this should not affect anything else.) Once I have the new one I make sure the screen works and that it is mainly functional ( the hardware in the frankenp3 will be mainly from the Ebay one so it still has to have some functionality even though it doen't need everything to work). Once I confirm that it works I take the backs off (remove the 4 screws and pry with your fingernail), the fronts off (remove the 4 screws and pry with your fingernail- just pry more gently) and pull the boards out of their plastic carrier by- after pressing the middle screw on a outlet plate- gently tilting the bottom end of the board( the one with the USB port) and pulling the board completely out. Flip the boards over. In the top right corner there is a second board floating on top of the main board. This is the memory module take the memory module from the old mp3 and put it in place of the memory module on the ebay board. You now have all the data from the old mp3 on your new mp3 and have probably fixed any problems it had. now just reassemble and it should be ready to use.
Posted on Feb 14, 2009
Daddy's gonna come around to mama's way of thinkin'
They always crack in the end; try constantly reminding him of it esp when he's tired-it won't be long...
Mar 11, 2015 | Audiovox XDRC2V1 XpressRCi Large...
Machspeed Eclipse 180v 4GB not showing all files
The problem is that you might have unplugged your device, before all of your songs could sync onto your device. Try plugging your device back up to your computer and sync the songs on there that isnt already on your device.
Jan 23, 2013 | Machspeed Eclipse 180RD 4GB MP4
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
My screen cracked
Repeat ALL is the circle without the "1" next to it.
Manual available at:
www.usasupport.philips.com
Screen cracked = out of luck - Philips does not sell replacement screens
Jun 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Black screen
looks more like the LCD screen cracked.
Jan 20, 2008 | Apple iPod nano
Computer does not show MP3 player as connected and how to stop a song playing
If you installed the firmware update, you might have forgotten to change the device to MSC mode.. try going to settings>USB mode>MSC This should probably work.. to stop a song while its playing, click the |<< button while you have the screen with the current song. (you can pause a song on this same screen with the >|| button) If you have gone back to any of the menu screens, wait for a couple seconds and the player will automatically go back tot he song display screen so you can stop the song.
Dec 26, 2006 | SanDisk Sansa e250 MP3 Player
Sansa e130
Does the battery need replacing? My screen is cracked and it appears the battery discharges quicker than normally. For now, I check the voltage on my rechargeables before installing them so that I know they are good. Try putting one song on to see if that will play?
Aug 07, 2006 | SanDisk Sansa e130 MP3 Player
Music won't play
Make sure you have downloaded the right format to your player and you may have to compress its size.
Jul 24, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
SanDisk Sansa e200 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
