Question about Motorola Mobility H710 Bluetooth Headset
Pairing H710 to a computer
I've been trying to pair my H710 to my laptop to use with Skype, but I can't get it to pair with the headset. It gets as far as asking for the passkey, I enter it, the headset flashes purple and blue, then it goes solid red for a few seconds, then I get an error on my laptop that the connection failed.
I've been able to pair it with my blackberry pearl and my PS3. I'm wondering if it's refusing to pair because it has two devices paired to it already. Do I need to wipe out all the pairing info on headset, or should it just pair and wipe out one of the devices when I try a third device? Does this headset not work with computers/laptops?
  • Anonymous Mar 03, 2009
    I was able to pair it with handphone but not with my macbook, so is it possible that the headset H710 cannot work with computer but the computer can find the headseat, so what is the pairing code?
I tried to pair the H710, but computer says no sw driver for this device.
the computer is new dell vostro 1520 with windows 7.
cg
Posted on Dec 01, 2009
Well. This is probably not a solution you guys want to hear, but it just worked. I left it for months, maybe it was just the time, or a recharge needed to wipe out one of the paired devices in memory, but it just paired with my laptop like that. Used it for while too with Skype.
I am also using the new Windows Seven RC this time around, maybe it was a Beta issue, that got fixed with the RC.
Posted on Jun 01, 2009
Here's what I did - Go to Control Panel and search for Bluetooth settings. Choose the option to change Bluetooth settings and check the "Allow Bluetooth devices to find this computer." After successful pairing, uncheck this box. All is good.
Posted on Dec 20, 2009
I am trying to Pair a Motorola H710 and need to know how?
To know the detailed steps for pairing, kindly download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Sep 04, 2010 | Motorola Mobility H710 Bluetooth Headset
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
How to connect my motorola H710 bluetooth with my mobile
You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location;
Hope you are able to sort your problems out.
Cheers! Carlos
May 09, 2010 | Motorola Mobility H710 Bluetooth Headset
I can't get my H710 to go into pairing mode... solid blue
First, if you've already paired it with another phone, make sure that phone is turned off. Close the headset and wait a few seconds, then reopen it by flipping out the boom (mouthpiece).
If that doesn't work, try this adapted method from the H700 model: Press the multi-function (center) button and hold it in until the light turns blue. As soon as you see the blue light, immediately open the boom (mouthpiece). Hopefully it will remain solid blue, indicating you're in pairing mode.
Jan 08, 2010 | Motorola Mobility H710 Bluetooth Headset
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 25, 2009 | Motorola Mobility H710 Bluetooth Headset
H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
Jul 27, 2009 | Motorola Mobility H710 Bluetooth Headset
My LG Voyager cannot find my Motorola Bluetooth H710
Jul 22, 2009 | Motorola Mobility Bluetooth...
Motorola Mobility H710 Bluetooth Headset Logo
2,585 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
