Question about Acer Aspire AM1100-B1410A Refurbished AMD Desktop PC - AMD Athlon X2 4000 2 .1GHz, 2GB DDR2, 320GB S ...
Want to get front panel off Acer Desktop - Help!
I'm not noob but I can't figure out how to get the front panel off this desktop to add second DVD drive.
The User's Guide is no help - no diagrams or instruction on removing even the side panel, which was easy enough.
Saw a post by thomaskenney about installing a DVD RW drive - Thomas, if you could let me know the way to get this panel off I'd appreciate it!
I've searched the web for a week and can't find any guides/manuals, and Acer is no help.
Please - I don't want to damage the front panel/case but I'm almost frustrated enought to grab a hacksaw.
  • Jay Moles Feb 11, 2009
    I'll try that - sorry for the dumb request, but I'm spoiled by Dell and Compaq/HP machines that have diagrams.instructions in User Guide and even put tabs for the front panel on the side where the easy-to-open side panel comes off.
    I'll try it out and rank it fixed if I see a way to get it off.
  • Jay Moles Feb 18, 2009
    I'll try to post the pics that show the process of removing the other side panel and then show the plastic 'tabs' that you press in to loosen the front panel.
    Thanks again LEECOM72!!
  • Acer Master
  • 4,806 Answers
Hi there
take off both the side panels, and look for screws behind the front panel, also look underneath the front panel for possible screws, once the screws have been removed the front panel should pop off and you will able to add your drive.
Good luck and thanks for using Fixya!!
Posted on Feb 11, 2009
How to add dvd player to m5641
Open the Left side of the case by removing the screws in the rear of the case, slide to the rear.
Jan 13, 2013 | Acer Aspire M5641 PC Desktop
DX38BT motherboard wirer hook up.
http://www.intel.com/support/motherboards/desktop/dx38bt/sb/CS-028327.htm
Click on the blue - English Product Guide [ PDF ]
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
Connecting to the Internal Headers
Page 50 for the PDF file page number. Figure 27. Internal Headers
The front of your computer is the Front panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Item I in Figure 27.
Detailed connections on Page 54.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | Systemax Venture PC Desktop
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
I want to put my acer motherboard into a tower as the flat desktop model is taking up too much space but I will need to know exactly where everything connects to the board (power, front panel,, on/off,...
Only a true Acer manual for this model of PC could assist you. They provide a special connector in this model, for the front panel connectors, that cannot be simply connected in a standard Desktop or Tower case.
Aug 26, 2011 | Acer Veriton 5600GT PC Desktop
Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
Sep 23, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
How do i remove the front panel to change CD/DVD drive? I do not have a manual for my desktop - I can remove the side panel but not the front panel. thanks you
You need to remove the side and then remove the front. The front is connected by latches which are on the top bottom and opposite side of the machine. Once you do that the drive should slide out the front of the machine. You may need to use a flat head screw driver to get the panel off.
Sep 07, 2009 | Acer Aspire M3641 Dual Core E2200 PC...
Opening front of AAspire M3201 case
The front panels usually are held in place with tabs. Take off the left side panel first, then the top and right side should slide off. You will need to remove any screws along the back and top edges first.
Good luck.
Mar 20, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Acer desktop
I can't find a decent picture of your case online or a service manual.
Can you take some pics and post them on photobucket or something?
I need to see the front and back of the desktop.
Feb 28, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Acer aspire t135 desktop doesnt start
Howdy...
I would shed the loads and measure the power supply (pinouts available everywhere on net) what that means is disconnect the drives and I/O cables to them (at the MOBO). Remove any recently added cards or ram . You should be able to see video and/or beeps if voltages are reasonable . A spare power supply would be handy .
Slowly add things until failure shows or if MOBO seems at fault ,try your stuff in another PC . There has been rash of swollen/leaking caps 'round these parts due to bad power supplies or bad caps . Bad power supplies can destroy the MOBO . Changing these caps will often resurect a MOBO
but this is not for the inexperienced desolderer as these
boards are multilayer .
Good luck
Hugh I
Jan 31, 2008 | Acer Aspire T135 PC Desktop
Acer Aspire AM1100-B1410A Refurbished AMD Desktop PC - AMD Athlon X2 4000 2 .1GHz, 2GB DDR2, 320GB S ... Logo
552 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
