Question about LG Washing Machines
Lg wm0532hw leaks from bottom
Leaks from bottom
You either have a loose hose on the drain pump , the main tub is leaking at the joint or the bearing on the main shaft is starting to go out.
Posted on Feb 20, 2009
Wm0532hw
Make sure that the small plastic feet on the bottom of the machine are all adjusted correctly so that there is no movement on the machine when rocked from side to side when empty.
Adjust by screwing in or out to get the exact level required.
Mar 09, 2014 | LG WM0642H Front Load
Front loading LG washer WM0532HW squeeking noise as drum cannot seem to spin with clothes full of water
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Aug 15, 2010 | LG Washing Machines
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Significant water leaks through the bottom on the front side as soon as cycle starts. Already cleaned out the filter and hose from bottom right corner. Any suggestions? LG Model WM0532HW
Check that the door seal hasn't got a split or hole in it. Check between the bowl and the front panel. The water must be coming from somewhere. could be a hole in the outer drum itself or it could be the detergent drawer overflowing.... As a last resort... Carefully take off the top by unscrewing the screws at the rear, bump the top panel back to unclip it and VERY carefully look while the machine fills. DO NOT TOUCH as there is bare wiring...Remember water and electricity make a shocking combination!!! ....Nomess
Apr 01, 2010 | LG WM-0532HW Front Load Washer
My LG Washer (model WM0532HW)leaks when it agitates. I looked underneath, and water is dripping underneath towards the front of the unit, possibly from the seal (?) Customer service would only tell me I...
Hi, open the door and check for any holes in the main boot/bellow's. If so you can either try a rubber "patch kit" or relpace the bellows. It is identified at repairclinic on-line as part # 1377586 and retails for approx. $55. Also check the bellows going from the bottom of the tub to the drain pump. It can also be the source of the leak. You should be able to examine it with the aid of a flashlight or trouble light from the opening at the bottom of you washer. If so repace it with part #1266823 also available at said vendor for around $15. Hope that helps. If so please leave a rating of how helpful this info was here at fixya. Thanks for coming to fixya and good luck. Macmarkus :)
Dec 07, 2009 | LG Washing Machines
I have a LG WASHER,FRONT LOADER WM0532HW KEEPS FLASHING LE,THE DRUM WILL NOT ROTATE
LE stands for locked motor error.  The first thing you should try is simply unplugging the machine for 10 minutes.  If the problem continues the next most likely cause is the hall sensor.  To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum.  Undre that wheel if the stator (motor).  At the bottom there is a sensor that spans about three of the windings.  This is the hall sensor.  It is not very expensive.  If neither of those work you will need to replace the Stator (motor)
Oct 22, 2009 | LG WM-2277HW Front Load Washer
Removing drum bearing on a LG wm0532hw???
Remove motor stator and push in the drum shaft as far as you can. Try to put a hook in between the shaft and the bearing and pull rotating in every direction and keep pulling outward.
Good luck
Jun 04, 2008 | LG Washing Machines
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
LG WM0532HW
I found a part number for a switch: http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6600FA1704X/New.aspx To see the full list of parts for this model: http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW.aspx
Sep 02, 2007 | Washing Machines
Washing Machines Logo
337 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
