Question about Dishwashers
Hobart WM-ES-3 does not draw sanitizer. Need manual
This dishwasher is located in a church kitchen where I am attending while on a winter break in Texas Feb 1 thru Mar 30 2009 They have no literature on this unit and I would like to repair the problem during Feb. Any help would be appreciated . Dale
  • robertnrbc Apr 02, 2009
    I would like to know where to find manuals/specs on web. I searched Hobart web site and can't seem to find info there.
  • 640 Answers
Tell me exactly your problem.I'm a hobart tech and repair these units often.
Posted on Feb 14, 2009
  • anthony james
    anthony james Feb 18, 2009
    How was me asking you a question inappropriate?Moron!!!!
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
REQUIERO EL MANUAL DE PARTES Y MANTENIMIENTO PARA SERVICIO DE LAVALOZA MARCA HOBART MOD. AM-14
Hola!
Aqui es un .pdf manual de lavaloza marca Hobart por el model AM-14. Espero que es posible que usar porque es in el ingles?
http://www.bakedeco.com/ebay/HobartDishwasher.pdf
Es posible que usar un tranlator en el internet si es necesario?
http://translate.google.com/#auto'it'
Jan 07, 2011 | Hobart AM14-253 Free-standing Dishwasher
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Need to hook up the small pipes for sanitazing agent
The other pipe is for detergent.Any other questions let me know i'm a hobart tech.
Apr 12, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Verifying breaker rating of AM-14
Commercial dishwashers don't take it for granted that the hot water is hot enough to sanitize. And, they know restaurants need to turn dishes.
So there is enough heat to make sure warm water heats up quickly to sanitizing temperatures.
Jan 29, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart LX30H washing to hot.
what temp is it washing at. washing should not be the problem. This machine is designed to rinse at 180 degrees + to sanitize dishes. The machine could be converted to a chemical sanitize, it would use bleach in the rinse water instead of 180 degree water to sanitize.
Sep 04, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart fx25 dishwasher
I think you may have the wrong model number of the dishwasher.I work for hobart but i dont recall a dishwasher with the model number you givin me.Look on the data plate again some examples of hobart dishwashers are--sr24---am14---c44---c44a---lx18--lx30--lx40---lxi---uw50--sm6t2.Once you find the model goto this site and you will find a manual.any other questions let me know.http://www.hobartcorp.com/default.aspx
Nov 22, 2007 | Dishwashers
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
