Question about RCA Universal Remote Control
Led light constantly stays on remote rcr4358
My batteries popped out of my remote and as I put them back in the led light on the remote wouldn't turn off. I don't know what this means but I cant program my remote the way it is.
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Posted on Feb 11, 2009
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
No response at all from power switch or the remote. will not power on. no blinking lights or anything
could be a dead remote test with a camera ie phone. look at camera on phone etc wile looking at the remote with the camera press the button if working there should be a light coming from the remote. if not the the inferred led may have gone in the remote easy to replace it is just soldered in. take batteries out of remote. there maybe a small screw in the bottom were the batteries sit. take that out. the with a flat blade on the gap between the top and bottom of the remote on the side. use a flat blade minding your hand etc wile doing this. and pop the cover off. when you have done this there is a led at the end of the remote. replace that with the same size ir red led and put back together remote should be working again.
Oct 01, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
The led on my lxa 600 watt amp in my dodge magnum
If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
Oct 10, 2009 | Car Audio & Video
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Changing a battery on a Cobra 7777 remote control
The battery in the 7777 remote is a CR2032. If upon changing the battery the remote fails to work then you should stand next to the car and hold down both remote buttons for around 10 seconds to reactivate it. The remotes LED will flicker rapidly during this process. Keep holding both buttons until the LED stops flickering then release both buttons. The LED should now be on constant, press the larger of the two buttons and the remote should now be re-synced.
Note: This procedure is not to program the remote to the alarm, but to re-synchronise it.
Aug 20, 2008 | 1999 Mazda 626
The red light stays on permanetly despite changing batteries on t.v remote control
I had this same problem as well. It was after I upgraded the OS I had the issue with my LED red light on constantly. I figured out it was the colorpearl application because it is not compatible with the new 4.5 OS.
Apr 20, 2008 | RIM BlackBerry Pearl 8100
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Televison & Video Logo
560 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
