Question about Whirlpool Duet GHW9150P Front Load Washer
Frontloader washer water not staying in tub during wash cycle
  • JOYCE BROOKS May 11, 2010
    Hi this is joyce
    What is it doing? I have the same machine.
    sounds like pump. but not sure
    go to whirlpool.com download your machine doc. put in your model # and get your doc .or let me know and I will go online and try to get more help for you.
    thanks
    joyce
  • 20 Answers
Make sure your drain hose is above the tub in the washing machine
Posted on Feb 13, 2009
Why is there no water in tub during wash cycle?
Check water feed pipes, taps/fawcets possibly the pump not working.
Jul 21, 2014 | Kenmore Washing Machines
Lint, and debris not going to filter
Generally speaking grass clipping etc will stay in tub on a hi efficiency washer. That's why the water level is very low also-high efficiency,low water use. Most LG washers have an extra water button to add a small level of water per wash.
Jan 16, 2018 | LG SteamWasher WM2650H 27" Front-Load...
My sensing light stays on during wash cycle and dishes are not coming clean. The wash arms are not spinning very fast during the sensing nor the wash cycle. Not sure if it is the control board or the...
I do not suspect the control is the problem,it could be a weak pump OR not enough water in tub to be circulated. The water level should be at or just above the level of the heat element if it is less..the water valve is bad and not fully opening or the water supply into that valve is restricted
Gene
Aug 23, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
I have a GE, 4 to 5 years old, Super Capacity WJRR4170G1WW. When it agitates, the drum goes back and forth with the agitator. I though it should stay still. Please advise.
sorry to say you have a very expensive to repair problem ):
the transmission has a brake built into which is suppose to hold the tub in place during the agitation cycle and then release on the spin cycle to spin. the brake isnt engaging and the only fix is to replace the transmisson which is very expensive.
it may work for awhile then as it gets worse and the tub moves more during the wash cycle water will slosch out of it all over the floor,sorry to break the bad new
Jul 19, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
When the tub is full of water it makes a grinding noise like the tub is rubbing on the base of the unit, and the tub will not stay balanced during the spin cycle?
The suspension of the tub is out of alignment. It is possible that the suspension , the dampers are faulty and lets the tub down with the weigght of the water, This also makes the tub go out of balance during the spin.
Look for faulty/stretched suspension springs, faulty dampers.
The tub must be rigid and kept up and a loadd of about 6-8 kgs must not push it down. set this accordingly.
Aug 23, 2010 | GE Profile WPRE6100G Top Load Washer
Oil is spewing into the wash tub during the spin
This may be a busted tub seal, but is usually caused by the outer plastic tub retaining grease and debris from previous loads. I would try running a hot water only wash cycle at full water capacity and adding a strong degreaser. This should emulsify any left over grease while also washing out the outer tub. If the problem persists, you may need to repeat the procedure. Remember that your washing machine transmission is located below the drum and tub assembly and is full of oil, but that oil simply cannot travel uphill.
Mar 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water leaks from under during spin cycle
There are multiple reasons why your washer would leak during the spin cycle. The wash tub seal could leaking, The tub bearing could be leaking, The carbon seal on the top of the tub boot could be worn. The water injector tube where it connects to the top of the tub could be torn from age. Even the tub to pump hose could have a hole in it. These are the most likely causes. There is one more item being the stem seal could be shot but this would cause water to leak all of the time.
Jan 06, 2010 | Maytag Washing Machines
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Leaking water washing machine -lxr9245eq1
sounds like a levelin problem check it in both directions and post back, also post model number TY
Apr 06, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
