Shredder SH2006PB Logo
Posted on Feb 11, 2009
Techko Model SH2006PB
Shredder will not accept paper. We already tried the small knife in the feed slot. It is no longer jammed. Thank you.
I am writing you again because we just changed our e-mail address today.
4 Related Answers
Anonymous
  • 48 Answers
  • Posted on Jun 04, 2007
SOURCE: Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Anonymous
  • 102 Answers
  • Posted on Feb 22, 2008
SOURCE: Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Anonymous
  • 2559 Answers
  • Posted on Feb 09, 2009
SOURCE: Ran hesitantly for 4 or 5 shreds Then would not shut off.
The feed switch located in the feed slot is jammed,you may be able to clear it with a small knife or screw driver.(just make sure to unplug the unit first)
Please rate this a fixya with the blue button below.
Anonymous
  • 35 Answers
  • Posted on Feb 23, 2009
SOURCE: Shredder does not pull in paper to be shredded
If it doesn't accept the paper, more than likely the gear coming off of the motor has broken teeth. I think for this model you have to call the manufacturer. Good Luck!
1helpful
Does this shredder activate when it senses paper being fed?
in the space where the paper goes to be shredded is a very small plastic level that is pushed sideways when the paper is put in
this lever is between two cutter blades and is easily jammed in the on position from paper bits
remover any paper around the center of the shredder that is blocking up the cutters
1helpful
How do I unjam it?
Techko SH1524CP Shredder Fix jammed - Questions - Fixya
www.fixya.com > ... > Techko > Techko SH1524CP Shredder
fix a jammed shredder? Remove as much of the jam as possible then saturate anypaper left with shredder oil or you may use any liquid vegetable based
1helpful
Techko shredder model #SH4205PD. The shredder stopped working. After unpluggung it and sliding the switch back and forth a couple of times it worked. Now it has quit working again. what coulf be the...
The micro switch referred to is to triggers from the presence of a piece of paper in the slot when on 'Automatic'. If this is stuck in the closed position it will easily be verified by placing a piece of paper in the accepting slot on the top of the machine. If it turns on it is stuck in the closed position. These shredders obviously get quite dirty and may simply need cleaning. Be Very Careful when working on any shredder! Also. the slide switch while basic in design has a number of wires on 8 poles and could also be the problem. As well if you these machines are protected by a thermal cut-off circuit if you overworked it give it sufficient time to cool down and reset. These are the most probably things to look at however, more in depth Dx may be necessary.
Good luck.
2helpful
2answers
Shredder runs continuosly
unplug the shredder and get aflash light look into the cutting slot.
there is micro switch in the slot.
must likely the switch is stucked, and not flipping back out.
try to use something thin clean off some of the glue (yes glue!) on and around the switch.
make sure the switch is free to move.
1helpful
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
1helpful
Help my paper shredder is not working.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Top Shredder Office Equipment & Supplies Experts
NOEL
NOEL
john h
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
