Question about Samsung ML-1630 Laser Printer
Paper jam error
I have a Samsung ML-1630 printer. It is giving me an error that says paper jam at tray 1. I have followed all the instructions in the troubleshooting guide with no success.
After I looked online for a solution I contacted the manufacturer and was advised to return the unit for repair.
Posted on Feb 12, 2009
My samsung ml1610 printer has red light online/error, with the smart panel installed it shows paper tray empty..but it isn't empty, it is with good amount of papers, i tried to remove and install the...
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://downloadcenter.samsung.com/content/UM/200709/20070911095810078_English.pdf
Aug 29, 2011 | Samsung ML 1610 Laser Printer
Paper now jams all the time in Samsung ML-2851. I have tried all the remedies in the manual but paper still pulls to one side and jams in paper tray or single sheet feeder. What part do I need to fix or...
Before loading the paper, you need to hold the stack of paper, and then tap it to make the stack even on all sides. Ensure that the paper adjusters on the tray are positioned in a right manner. Push the stack of paper into the tray until it stops. Never try to force the paper too far in the tray.
Dec 31, 2010 | Samsung ML-2851ND Laser Printer
Samsung ML-2250 the printer is no longer able to feed paper from paper tray. Just spins and doesn't print.
Hi, the only suggestion I could give you is to look where the paper leaves the tray to make sure there are no pieces from a paper jam. Some people even tried using a vacuum cleaner to try cleaning it out.
Other suggestion is to make sure you have the proper paper size selected.
Start, control panel, printers, your printer, printer preferences.
The mechanism that lifts the paper in the In tray up to the paper wheels may either be jammed or broken.
I guess that will help.
Thanks for using fixya...
Oct 28, 2010 | Samsung ML2250 Laser Printer
I have a paper jam in tray 2 and ive tried everthing
There could be still pieces of paper left in the printer. May have to take apart to remove.
Jul 29, 2010 | Samsung ML-1630 Laser Printer
After freeing a paper jam on my Samsung ML 1750 the On line/error
Frequently a very small scrap of paper is caught in the paper path. Take out all the trays and the toner cartridge. Then look very carefully with a flashlight for the smallest scrap left behind.
May 12, 2010 | Samsung ML 1750 Laser Printer
Printer jammed - removed jam but paper guide not resetting and on line error remains.
Had the same problem. Make sure you have put enough paper in paper feed tray (more than 10 sheets) and lock paper from sides. Take out ink cartridge and reinsert it.
Hope this works for you ^_^
Jul 17, 2009 | Samsung ML 2010 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ML-2510 Series: the error red light is blinking
reset the printer by opeing the front over and closing it again.
check all area for paper jam. i.e.: paper tray, ink cartridge, out put tray.
Feb 28, 2009 | Samsung ML-2510 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Samsung ML-1630 Laser Printer Logo
670 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
