Question about Samsung LN-S4692D 46 in. LCD HDTV
White line at top of screen on some channels/shows
It's under warranty... is this a warranty issue? it's not really a line because it is a little thicker in spots and kind of moves like a twinkling star all the way across the top of the image when it is pillar boxed, like on MSNBC. it doesn't show on the black edges, just above the image area. it's anoying. is it a tv problem? What can I do? thanks!
  • Anonymous Feb 18, 2009
    There are random white line on the top while watching some nonHD channels.
  • 335 Answers
Most certainly a warranty issue! take it back and get a new one. this is a common problem with these particular models.
Posted on Feb 11, 2009
White band from top yo bottom of screen
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
Apr 11, 2014 | Sharp LC60E88UN 60 in. LCD TV
My t.v. is an sylvania and the screen is all black with a white line going across the screen. It only shows images where the white line is and the white line is very thin. how can I fix this problem or...
Sinegalnatal -
Sorry to be the bearer of bad news, but that sounds like your TV is broken. There's very little chance that you'll be able to fix it yourself, as modern televisions are incredibly complicated and dangerous to work in without training. I'd suggest sending it in for service if it's still under warranty. If not, you could look in to a local TV repair place.
Mar 03, 2011 | Sylvania Televison & Video
Vertical lines on my Samsung LNCT4665FX HDTV LCD
When you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung hdtv model LE32R74BDX. I have had it now for just over a year and appox. 6 month later we had 3 black lines to the left of the screen about 3cms apart. The lines are quite thick and start...
Mar 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
Jan 07, 2008 | Televison & Video
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Samsung LN-S4692D 46 in. LCD HDTV Logo
132 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
