Question about Dell Latitude C610 Notebook
Hard rive not found
When booting up systems harddrive is not found,but it is in the right slot.don,t understand what could be going on with the systems, if someone has this same kind of problem please let me know.
  • Dan rogers
    Dan rogers May 11, 2010
    http://www.whitecanyon.com/how-to-change...
    It isn't letting me post any links so you will have to copy and paste the address in the address bar of your browser
  • Dan rogers
    If your computer cannot find a hard drive during boot it could be a couple things. First i want you to follow the link and check your settings in bios.
    whitecanyon.com/how-to-change-boot-order.php
    If the drive is set up in bios then you most likely have a bad drive
    Genius:
  • 1,913 Answers
I think u connect external harddive usb right.
go to my computerproperties then u see hardware clik on it then u see device manger clik on it then uninstall usb all drivers then just right lcik any one u see scan for hardware changes clik onn it all usb diverd are auto matically install.
Posted on Feb 11, 2009
Boot device not found
1) BIOS Setup states no harddrive found? Remove all power. AC adapter (Charger), and Battery. Remove Harddrive. Press Power On button in, hold in for 10 seconds, let go. Do this procedure 2 more times.
Reinstall Harddrive, and then Battery. Hook AC adapter again.
Harddrive recognized now?
You press the Power On button. This in turn presses against the Power On switch. The power is initialized. First chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized. BIOS LOOKS TO SEE WHAT DEVICES ARE INSTALLED, does a Ram Memory count, and hands the computer over to the Operating System.
This is what I am basing the above on.
2) Not to knock sellers on Ebay, as I have found a few that are decent.
However the motherboard could be bad.
Harddrive controller could be bad.
Southbridge chip of motherboard chipset,
(CPU = Processor),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
3) Don't E-slap me, but you were wearing an ESD wrist strap, with it's alligator clip attached to a good ground source; when replacing the motherboard, correct?
Please post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Hi Im having a problem booting, it appears on my screen PXE-E61: Media Test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating System not found. How can i fix this one without a...
it's trying to boot up from the network instead of from your harddrive. It could mean that it's unable to find your harddrive. One thing to check is the BIOS settings for the boot option - make sure the harddrive boots BEFORE it tries to boot from network.
Once you turn on your laptop it will tell you what to press to get in to the bios to change these options (could be either F1, F2, F10, DEL or maybe even something else) Once in the BIOS look for BOOT OPTIONS
May 04, 2011 | Toshiba Computers & Internet
Dell Inspiron 14R Laptop. Daughter spilled liquid on keyboard and now when i turn on laptop screen says: For Atheros PCIE Ethernet Controller v2.0.2.3 Check Cable Connection! PXE-MOF: Exiting Intel PXE...
Ya sounds like the hard drive has died or there is a interface problem since you suffered from water damage. you may be able to get data off the hard drive by using a external hard drive connector but it may or may not work.
Mar 20, 2011 | Dell Latitude D600 Notebook
When turning on system sylvania name will appear with a message at bottom of screen telling me to press f2 or f10. If I dont press anything it will go to a black screen, at the top left corner it says...
Well, let see, it saying that operating system is not found. This mean that there is no operating system loaded. It is 80% that your hard drive is currupted 19% that the operating system is damage if your harddrive is not damaged... unless you have a operating system load to a external source such a usb thumb drive, flash driver. If you didn't. then most likely your hard drive is currupted. The only way to see this is to press the f2 or f10 which ever key that load the bios menu which is a blue menu after you press it. Then see if the hard drive is detected. If not then your harddrive is bad and needs to be replaced and a Os is need to be reinstalled in order to work. If you have another laptop or a desktop that can accept sata drive, you might want to test this if the other computer would detect it as in some case the expansion slot for the harddrive could come worn out and couldn't read your harddrive. But most of the time, it is your harddrive, it is bad and need to be replaced.
Jan 14, 2011 | Sylvania G-Netbook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
Pxe-E61: Media test failure, check cable error I put in a new hard drive and need to boot up the computer
It seems that your hard rive is not connected properly and the system is trying to boot from the network as configured in BIOS settings
Aug 13, 2010 | Computers & Internet
I tried the hot swap harddrive and now its having harddrive boot problems. What do i need to know about swapping out the drives?
TOOLS NEEDED
hard drive pins (located at the back of the hard drive)
be sure to pin your hard drives accordingly ,primary drive to master (ma)and secondary drive to slave (sl) if you are running 2 hard drives
or pin the hard drive to cable sellect (cs) if you are running single hard drive
if 2 hard drives running the master hard drive has to go at the end of the ribon cable and the slave hard drive goes into the slot in the middle of the ribon cable.
if you hot swap aka pulled drive wile the computer was on you might be able to do a c mos reset perhaps you are using a usb drive if you are using a usb drive you might have to go through system admin to bring your system back up by using a confirmed drive you have booted up from before.
be sure in c mos that the usb feature is enabled sometimes by defalt usb dissables.
i hope this helped.
Oct 21, 2009 | IBM Netfinity 6000R 8682 Server
Acer 3000 not loading
Hey,
firts put the original harddrives back in place :)
then you need to enter the 3000's bios If I remember right
thats done by pressing f2 or del in a acer. it should tell you what button is correct on the bootup screen.
Then you need to change the boot order to haveing the dvd/cd drive before the harddrive, since right now its booting strate from the harddrive.
Then you should be able to restore the operateing system with the disks that came with the laptop and or from a normal xp or vista cd/dvd.
good luck!
Feb 14, 2008 | Acer Aspire 3000 Notebook
Dell Latitude C610 Notebook Logo
32 people viewed this question
Alun Cox
