Question about Sakar Digital Concepts 3 Piece Cleaning Kit with Screen Protectors & 5 Flexible Tabletop Tripod
Tv screens i can't seem to clean the tv screen it is a 54in. rear projection with a plastic screen ,what should i be using? and should the set be off when doing so?
  • 4,806 Answers
Hi there
You can clean the screen with antistatic wipes or just a clean damp cloth, don't use any chemical fluids on the screen or you will damage it and turn it milky white, and you can clean it while its on.
Good luck and thanks for using Fixya!!
Posted on Feb 11, 2009
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
How can i clean the screen
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user\'s manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV\'s can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can\'t tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it\'s extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions. GA_googleCreateDomIframe(\'google_ads_div_TL-IMU-Article\' ,\'TL-IMU-Article\');
Jun 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
7P5441 C101 54in color is wrong
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Bug parts or debris between screen cover and screen.
All from the front. Pull off the bottom speaker grill. No screws just pull straight back. There are rubber post that hold it. Next remove the screws on the bottom of the screen assembly. With them off you should be able to slide the screen assembly up about 1-2 inches and take off. This model does have auto convergence so the screen may have wires hooked to the back. With the power off disconnect the leads before setting the screen assembly down. Cleaning should be with a plastic cleaner not windex. If you do have to remove screen parts it's fairly obvious. Be sure to reassemble the same order and make sure you have help these parts are delicate when separate.
Mar 22, 2009 | Hitachi 50UX57B 50" Rear Projection...
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Feb 21, 2008 | Televison & Video
TV Projection filter screen
I would not use any kind of chemicals on the screens, I definitely would not use any liquids on anything besides the screen protector, the inside screen is a Fresnel lens and will wick up moisture, the one with the vertical grooves is the Lenticular and either one will leave a mark, if you have to use liqud, I would try distilled water, but no guarrantees you will get it clean. I usually end up replacing the screens. Looking at your post you said filter, do you mean an air filter? I dont think these sets us an air filter, if it was just dust a t-shirt or microfiber towel usually work, the towel being my choice.
Jul 07, 2007 | Philips Magnavox 51MP392H Rear Projection...
Please Help with color & screen Cleaning
You are going to have to adjust the three screens in the front of the set behind the speaker cover. You will need to adjust the Red, Green, and the Blue all to look like a B & W picture so turn down the color or put in a B & W movie from a DVD or VCR. Then adjust each screen till you get the best blend and a good grey scale. Grey scale is the best B & W you can get on the TV set. The screen has two surfaces on it. The outside part goes up and down and is called the lenticular screen, and the inside part has round circular pattern too it and is called the freznel lens. The circular screen and the outside screen can be cleaned with a car polish cloth called a Shammey. Use deluted windex and only wipe the rag in the direction of the screen, eather up or down or circular. Good Luck
Mar 24, 2007 | RCA P52955 52" Rear Projection Television
Picture problem
The remote control for the TV sets 16.9, 4.3, 16.9 zoom etc... Use the two buttons I highlighted in yellow to change the screen size.
Feb 22, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sakar Digital Concepts 3 Piece Cleaning Kit with Screen Protectors & 5 Flexible Tabletop Tripod Logo
Top Sakar Photography Experts
pontelemon
pontelemon
Are you a Sakar Photography Expert? Answer questions, earn points and help others
