Question about Saeco Vienna De Luxe Espresso Machine
Liquid leak while Vienna runs...but where from?
I clean/rinse my Saeco Vienna machine daily, I brew approx. 3-4 espressos each morning, have had the Vienna for about a year. A month or two ago I started to find liquid underneath the pull-out tray after brewing, rather than in the tray. This liquid apparently travels toward the front of the unit, seeping down into the right side hole in the bottom front of the plastic base, wetting the countertop underneath with a combination of liquid and coffee grounds. Every removable part looks clean, is clean, everything fits together closely and properly so the unit always runs OK, water tank O-ring and spring look fine, I de-scaled the machine a couple of weeks ago, so why am I getting this leak, and where does it originate? Any good guesses?
  • liteman227 Feb 21, 2009
    This morning I decided to find my leak. I have had my machine apart before, but do not know how to get the guts (being a darker color gray than the outside of the machine) out to repair the leak I discovered. One of the brass fittings that has a thin plastic hose connected is wet, and when brewing, actually drips. Since I cannot figure out how to remove the insides, I think I'll just find a round tray that the whole machine can sit inside of. Not a fix, but it will keep the counter and floor from getting wet.
    If anyone knows how to get the darker part of the machine apart from the lighter part, I'd love to know how. It feels like something is holding it in place, like a clip or a hidden screw.
    Liteman227@yahoo.com
  • 3 Answers
I have had the same problem and here is what I did to fix mine.
When you take the brew group out there is a small spout (about 3/16") in the back that looks like a D on it's belly. This was clogged on mine. I used a toothpick to clean it out. I then poured water in the opening above the spout to flush it out.
Hope this helps!
Posted on Feb 22, 2009
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Posted on Feb 12, 2009
Leaking Saeco lpus vienna machine
Keep cleaning...make sure that run off spout the leads to the tray is 100% clear. Run water through it (with a sponge for example) to make sure you get all the sludge out. Careful about what sort of coffee you use. I have had bad luck with Illy coffee unfortunately.
Apr 01, 2014 | Saeco Vienna Espresso Machine
My Saeco Vienna espresso machine is leaking (rather clean) water on the bottom plate of the machine. What can be the cause and how to overcome it? Thank you for the answer!
if the water is clean -it could be the boiler,if is not exactly clear water -just clean under brew unit motor-when take off brew unit.There can be durty coffee
Aug 30, 2013 | Saeco Vienna Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
I need instructions of how to clean the Saeco Vienna Superautomatica in and outside. We lost the manual.
-Rinse Brew unit under warm water, and let dry.
-Rinse coffee tray, water tray and water tank under hot water (may melt in dishwasher)
The rest coffee been tank and exterior needs to be washed with a warm cloth, just make sure it is not to damp, which could leave water drops in the grinder.
Feb 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
My saeco vienna water is leaking out from somewhere underneath
If it is coffee colored water, then remove the brew unit and look under the white plastic valve in the machine, you will notice a small chamber, clean chamber of coffee grounds and make sure the little discharge to the draintray is also clear. Insert brew unit and check machine.
Jan 27, 2010 | Saeco Vienna De Luxe Espresso Machine
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
247 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
