Question about Philips 60PP9352 60" Rear Projection Television
Color blur looks as if it is a 3d screen that you would need 3d glasses to look at the picture. The red is off and there is a faint blue wave at the bottom of the screen.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Color blur - 2c07611.png /> 2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 12, 2009
  • 4,234 Answers
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs to defective ICs. If you can solder you should be able to resolve this yourself. Let me know if you wish to attempt the repair and I will furnish additional info and instructions.
Dan
Posted on Feb 11, 2009
When i turn it on, it gets a blue looking shadow color and the letters and numbers look like you're watching a 3D picture without glasses
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Hitachi 60DX10B 60" Rear Projection...
Turned on tv and it looked like 3d. Found red horizontal convergence lines extremely bowed. Cannot correct with magic focus either in auto or manual. What is the fix and what is more cost effective ......
TAKE OFF THE FRONT PANEL AND FIND THE FOCAS ELECTRONIC FOCAS CONTROLS. USUALY BETWEEN THE LEFT SPEAKER AND THE FIRST CRT GUN. PAUSE A DVD WHEN THE CREDITS GOING. OR USE A MENU IN YOUR SAT RECEIVER TO LOOK AT. USEING THE GRID IN THE TV SOMTIMES IS NOT ACCURATE. YOU WILL SEE 6 SMALL KNOBS (RED,GREEN,BLUE)FOCUS AND(RED,GREEN,BLUE)SCREEN DRIVE .FOLLOW THESE STEPS 1 TURNDOWN RED AND BLUE SCREENDRIVE 2 FOCUS THE GREEN (YOU SHOULD SEE SCANLINES) 3 TURN DOWN THE GREEN SCREENDRIVE 4 TURN UP THE RED SD UNTILL YOU SEE RETRACE LINES THEN BACK IT OFF TILL THEY ARE GONE. 5 FOCUS RED (UNTILL YOU SEE SCANLINES) 6 TURN RED DOWN AND TURN UP BLUE 7 FOCUS BLUE (BLUE WILL NOT BE AS GOOD AS RED+GREEN NOW YOU ARE IN FOCUS, NOW YOU NEED TO GET SCREENDRIVE BACK THE BEST WAY IS TO, PAUSE A DVD ON A BLACK SCREEN SELECT PLAY MOVIE AND HIT PAUSE RIGHT AFTER . TURN ALL THE LIGHTS OFF IN THE ROOM AND USE A SMALL FLASHLIGHT TO ADJUST SCREENDRIVE SO YOU DONT MOVE FOCAS BY MISTAKE. THE TRICK IS TO END UP WITH A VERY FAINT GRAY SCREEN WITH EACH COLOR UP AS FAR AS YOU CAN WITHOUT SEEING ANY COLOR ON THE TV. WHEN YOU GET THIS TRY PLAYING THE MOVIE. MAKE SURE THE BRIGHTNESS AND CONTRAST IN THE TV ARE AT A NORMAL LEVEL BEFORE YOU START . COLOR,BRIGHTNESS,AND FOCUS IS NOW SET TO YOUR DVD PLAYER.DO A FINAL CONVERGANCE AND YOU ARE DONE!
IF YOU CAN'T GET A COLOR TO FOCUS YOU MAY HAVE TO DO THIS MANUALY. SOME TV'S YOU CAN LOOSEN THE NUT ON THE CRT LENS AND MANUALY FOCUS IT. (LIKE AN OLD CAMERA). IF YOU GET THIS FAR YOU MIGHT AS WELL CLEAN THE LENS WITH A VINEGER BASED GLASS CLEANER (SPRAY THE RAG NOT THE TV) TAKE A LOOK AT THE MIROR, CLEAN IF NEEDED. IF THE MIRROR IS REAL DIRTY THEN THE SCREEN MUST BE BAD TOO.TAKE THE SCREEN OFF AND CLEAN THE BACK SIDE IF NEEDED. LOOK INTO THE LENS AT THE PICTURE TUBE YOU SHOULD SEE A NICE BRIGHT CLEAN PICTURE IF IT LOOKS CLOUDY YOU NEED TO CHANGE THE LIQUID IN THE CRT GUNS.I DON,T THINK YOU WAN'T TO TRY THIS YOURSELF. TIP(I USE A LITTLE ARMOR ALL WHEN I CLEAN LENES, THIS REPELS DUST LIKE IN YOUR CAR) IF YOU CHANGE YOUR FLUID AND WANT TO KNOW WHERE TO GET NEW FLUID I PUT CLEAR ANTIFREEZE IN MY PIONEER TV 3YEARS AGO AND STILL LOOKS GREAT "NOT KIDING" HOPE ALL THIS YOU. IF YOU ARE NOT COMFORTABLE TO DO IT. HAVE IR SERVICE. REPAIRING THIS WILL BE YOUR BEST OPTION>THANKS
Jan 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Picture show blurred and 3 lines across the screen color of red, blue and green
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wave & three colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Display looks like you need 3D glasses to view.
Sounds like a convergence problem. Especially since you said that the screen(picture)wasn`t linear anymore.
If the magic/touch focus function doesn`t clear the problem then your convergence modules may be faulty. They are used to align the three tubes (red/green/blue) deflection. If you feel handy with a soldering iron i could assist you in replacing them, otherwise you might need the help of a local repair tech. Hope this help. Good luck
Dec 01, 2009 | Televison & Video
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC AV-48WP34
The convergence ICs need to be replaced. I can post a link where to get replacement ICs along with free step by step instructions so you can do the repair yourself. Its an easy ,common repair , however a shop will be around 300 to 400
Mar 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
Then it is likely the pre-amp transistor that controls the red is shorted out.
hopefully you have extended warranty.
there is a trick to likely get them aligned anyway if this is a tube tv.
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
