Question about HP Laserjet M2727nf Multifunction Printer
Thick gray vertical line printing on the left hand side
Help
    Problem Solver:
  • 11 Answers
Sounds like the drum is bad. Replace the drum with a rebuilt or new, and these lines will go away. Might want to take it to a tech, or have them come in and clean it as well. Toner everywhere in the cartridge area makes for messy prints. If you attempt it yourself, take the cartridges out, unplug from the wall. Use only the plastic ends on your vacuum sweeper and either brush the ink to where it sucks up the hose or use just the suction to get the dry ink out of the printer. Once clean and new drum installed, your printer hopefully will give you quality prints again.
Posted on Feb 11, 2009
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Sony Bravia 32in ... vertical gray line on right side of the screen about 4in from the edge of the screen. The line is about 5mm thick and present on all inputs. More visible over brown and blue...
The line should be visible, even with the television off. It is called "de-lamination" of the LCD panel, and occurs in lines, usually vertical, on the screen.
The panel does need to be replaced. You can contact Sony at 1800-222-SONY. They are good people, and should be able to help you.
Hope this helps...
Jan 05, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Says ready, error light blinking, vertical non-print line
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Aug 13, 2008 | Konica Minolta magicolor 2400 Laser...
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Hp LaserJet 3015 Printer.
is it wavy? if so then it is either the toner cartridge or the fuser unit (heat section) I would go for the fuser unit as the hot roller that makes the toner stick to the paper is only a plastic film. Have you noticed any gray pieces of plastic coming out?
Hope this help you and you can get these machines repaired also please rate me
Cheers J
Dec 28, 2007 | HP LaserJet 3015 All-In-One Printer
HP Laserjet M2727nf Multifunction Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
