Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
No water at flush
I have a Eljer pressure assisted water closet model # 150 - 403. My problem is that it will flush fine, but at times it will not flush at all and we turn the water off and on and it will flush fine for a while the we have to repeat the on/off cycle. Thanks for your help.
    Genius:
  • 1,605 Answers
Sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Posted on Feb 11, 2009
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
The water wont fill back up after you flush it
MAKE SURE THAT THE HANDLE OR CHAIN IS NOT GETTING HUNG UP ON SOMETHING INSIDE OF THE TANK,WATER WON'T FLOW UNLESS THE FLOAT DROPS DOWN
Apr 05, 2010 | Eljer Walford Two-Piece Pressure-Assist...
Always have to hold handle to get it to flush
lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Sep 10, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Want to know how to remove the flush alve on a one piece toilet.
Open the rear lid of water closet. on the very inside rear of the flush valve there is a very then nut it unscrews in the clockwise rather then counterclockwise. I think that was the problem
Jul 01, 2009 | Eljer Toilet Onepiece Canterbury ...
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
431 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
