Question about IBM ThinkPad T43 Notebook
Wireless signal intermittent
I have a D-Link DWA-3200 Wireless Gateway router using a static ip address connected to a cable modem which has the same static IP. I have 2 d-link dwa-3200 access points, one connected wired to the router and the other is on the floor above. The one on the floor above is not connected hard wired, it picks up the wireless signal. What could cause the intermittent signal that people are getting as they use the wifi? I tried switching channels, but when I unplug the cable modem, router, and two access points then reconnect them in this order: cable modem, router, then access points, it works fine for a while. I have a feeling it may be something with the amount of bandwidth - people using it. It is in a public library
  • 8 more comments
  • Joseph Murphy
    Joseph Murphy Feb 11, 2009
    I noticed I have it under the wrong category
  • Joseph Murphy
    How do I set one of the access points to be priority? The access points one on each floor, are set to WDS and the mac address points to the other access point. The DSA-3200 wireless public gateway is connected hard wired to one of the access points, then the other access point picks up the wireless signal, it is not hard wired.
  • Joseph Murphy
    The computers that are losing the connection are wireless. The computers patrons use at the library connect to either the access point thats connected to the gateway router or the other access point on the main floor which uses WDS to connect to the other access point.
  • Joseph Murphy
    I configured each of the two access points with the rogue ap and selected the other access point added it to the list. I deleted the others that came up when I hit detect. Would that help? The wireless is connected to the cable modem, giving patrons access to the internet. Our main network is static ips.
  • Joseph Murphy
    I'm using wireless G, the router and two access points are set for mixed b/g. I have NetStumbler on one of our laptops, but I don't think I have a bandwidth monitor. What program would you recommend?
  • Dan rogers
    Dan rogers May 11, 2010
    Have to say i just downloaded the net stumbler and that is a pretty slick little program. Looks like i'm gonna have to learn how to use this one. thanks for turning me on to this one
  • Dan rogers
    the first issue i see is that you are running a G network. This should work since most older laptops run G but it could still be an issue.
    To monitor the bandwidth try using something like this...
    http://sourceforge.net/projects/freemete...
    I don't have much to recommend or offer here. At work we have a fatpipe that does all this for us. But we are in the middle of trying to implement the wireless network since we are soon expanding to the third floor. The best we have got so far is running routers that have G/N networking and even still on the third floor (routers are on the forth) we have limited connectivity. In our case we know that it is limitations based on the actual building itself.
    In your case however it seems that if it is just dropping the internet and not the network connection that it is a bandwidth problem
  • Dan rogers
    Before we start digging real deep into this problem do you have a program that monitors the bandwidth usage? and are you running wireless G or N?
  • Dan rogers
    Are the computers that are losing the connection wired or wireless?
  • Dan rogers
    It could be the bandwith. But i am also thinking that it is switching the connection to the rouuters. Can you set one of them to be priority?
    Problem Solver:
  • 5 Answers
First make sure you have the latest update for your bios and wireless device, your os is probably non preload so clean any access connections utility provided by ibm, rather than using the ibm thinkvantage access connection make sure to use the windows own utility to control the wireless device
Posted on Feb 13, 2009
  • Ginogin Feb 13, 2009
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
I have 2 laptop computers with built in wireless and I am trying to connect to internet via a D-Link 615. I have tried multiple things but it keeps telling me that my cable is disconnected and I have no...
HI. you have to check first what kid of modem u have.. im sure if the laptop is connected directly to the modem, u have a wired connection and u can connect to the internet.. if ur modem is a cable modem, u need to mac clone the mac address of the computer that can connect to the internet. u need to connect the computer that can connect to the internet to the router and do a mac clone and the internet connection settings is dhcp..if u are using a username and password to connect to the internet, u need to use the pppoe settings on the router, and if ur isp give u a static ip address, u need to set the router on static ip. how u can check the ip address, click on start, run and type cmd and it will show a dos prompt, type ipconfig/all and it will list the ip address, subnetmask, default gateway and dns server.. u need to setup the router first in order to talk to ur modem..
Jul 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Couldn't get internet via Wirless Router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
With the steps that I given to you, it was mention earlier that u used the pppoe, dhcp, but not static ip, if your computer is directly connected to the adsl modem it works perfectly. this is the specs of ur modem:
Supporting 1483B bridging and routing function Supporting DHCP server, NAT/NAPT , PAP/CHAP, IP Filter, Firewall, protocol block Built-in PPPOE/PPPOA dialing..
you can try two option:
1. your modem is equip of supporting dhcp server, if u can access ur modem and set it to bridge mode so that the dhcp server wont conflict with the router bcoz the router has a dhcp capabilities as well.
2. you need to disable the dhcp of the router so that the modem will act as the server and will give ip address to your computers..
this 3rd option will be your last solution if both dont work..
try to check the ip address of the modem, if the the ip address of the modem is 192.168.1.1 and the ip address of the router is 192.168.1.1 as well, connect your computer directly to the router and change the 3rd octet of the ip address, ex-192.168.1.1 to 192.168.2.1 then your connecttion should be , the cable form the adsl model goes to the port 4 of the router and the router should be set on a dhcp settings..
I hope this solution will help you. good luck
if you have any querry pls feel free to get in touch.. good luck
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
IBM ThinkPad T43 Notebook Logo
404 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
