Question about Campbell Hausfeld 13 - Gallon Air Compressor
Fuid inside compressor..do I undo drain plug !
I have a 13 gallon compressor WL650101AJ. There is a drain plug on the bottom..I can hear fluid swishing inside body of compressor. Should I undo the plug at the bottom..I started to but a black fluid came out?
  • terrawoods Feb 11, 2009
    Perfect ansr..thanks for the help! I'll go try it now!
  • 333 Answers
Open the plug at the bottom of the tank while the compressor is on so that it will blow out all the crud. The black liquid is the gunk from the oil in the compressor and staknant water. When the crud stops coming out and you herar just air, you should close the valve and you are set to go. You should drain this tank al least once a month if you use the compressor a lot. I hope this helps. Don't forget to rate my answer. Thanks.
Posted on Feb 11, 2009
2003 highlander how do i spray starter fluid in air filter
Undo the clips on the air filter housing and pull the top part off then spray the fuid inside the top part of the housing/
Nov 15, 2017 | 2003 Toyota Highlander
Husky 25 gallon compresor reaches 115 psi, not any more and keeps running, does not shut off
If it is not getting to pressure then either your safety valve is leaking or the drain plug on the bottom is open. Do you hear air escaping when it is running?
Nov 19, 2016 | Air Tools & Compressors
I am changing the transmission filter and gasket, where is the drain plug for the fluid and will that drain everything out or do I need to disconnect any hoses? Thanks
Some automatic transmissions have a drain plug on the pan, most don't. The fuid on the drain pan is drained as the pan comes off the transmission. Most torque converters don't have a drain plug, few do. Generaly, most of the fluid remains in the torque converter, many pints of fluid. The best change in this case is to do a transfusion of the fluid at a shop. Some people disconnect a fluid hose to coolant in the radiator and pour the fluid in the filler hole quickly with the engine in idle as the fluid drains out the disconnected hose. I'd rather take it to a shop for a trans fusion
Mar 14, 2015 | 2009 Dodge Avenger
Where is transmission filter
My understanding is that it is inside the transmission. You drain the fluid (hopefully there is a drain plug) and remove an access cover plate, or more likely, the transmission's bottom cover to access the filter. If no drain plug, oil will "self-remove" when you loosen the cover - be sure you have a large drip pan with at least a gallon capacity or lots of oil absorbent (kitty litter works well!).
May 20, 2013 | 1998 Chevrolet Monte Carlo
My Campbell Hausfeld compressor model WL650101AJ will only pump to 80psi and will not shut off.
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Jan 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Transmission fluid capacity for 2008 Lincoln MKZ? in quarts
If you have the Asin Trans which most MKZ' woth V6 engine of that year such as my own MKZ take 7.4 quarts dry, probably about 5 if just removing the drain plug on the bottom. there is a drain plug which takes a large torx socket to remove, no filter because the valve body is located on the uppper side of the trans and not the bottom like normal transmisions. the fluid is a special fluid ,Motorcraft
XT-8-QAW Fuid.I would not rust any after market brand which says it is compatable. It can be bought at a ford dealer, or I even saw it for sale on Ebay. Hope this helps, you exact trans type can be found in your owners manual as well as on Fordowner.com if you make a profile and add your VIN of your vehicle to your garage. You can download manuals there and even make service appointments
Dec 30, 2010 | 2008 Lincoln Mkz
Valve on top of engine spews oily fluid
Drain the water from the tank, usually at the bottom of the tank, lowest point.... Be prepared for a flood!
Feb 11, 2010 | Astro Air Tools & Compressors
Need to replace bearing on pump/motor unit
if this is oi les pump it was not designed for bearing replacement on the motor. check with your local elected repair shop thy my be able to help you
Oct 14, 2009 | Campbell Hausfeld Air Tools & Compressors
Wont pressure up
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Takes forever to pressure up
Double check that the drain valve is fully closed on the bottom of the tank. Once it reached 100 PSI, did it stay pressurized or did the pressure drop? Did you run the initial break-in procedure described in the manual? Do you hear any air leaks?
Oct 26, 2008 | Makita MAC2400 13 Amp 2 1/2 Horsepower 4...
Campbell Hausfeld 13 - Gallon  Air Compressor Logo
528 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
