Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Sears Dishwasher in " Lock" position
Model No. 1603. The red light indicating Lock is on and I can't get it to go in the Off position. Have tried holding Heated Dry pad for 4 sec. ..niothing happens. Have turned off the Main Electricty to unit and The Red light is still there.when turned back on. What do I do ?
  • amau56 Feb 11, 2009
    The Red Lock light has been on for 3 days
  • amau56 Feb 15, 2009
    Solved the PROBLEM ! After looking at others , even if the owned a Whirlpool...I pressed on the Cancel/Drain pad...I just held it until it lit up and the Lock lite went out. The I pressed on the LOCK lite and held it and IT WENT OUT ! The dish washer is now up and runnig ! Now I can use the Stimulas Check on the car !!! Good luck everyone !!!
Unplug the power longer, or its sounds like a wash delay setting is programmed
Posted on Feb 11, 2009
Kenmore Elite 665.1392 / 665.1394 Control Lock Light is on. No other buttons are responsive. Dishwasher won't run.
The control lock should toggle on and off if you press and hold that button (on the right side of the group of buttons) for 3+ seconds. Until the lock is released, the other buttons won't work. If the lock won't release, either the keypad or the control board are not communicating the unlock signal between them. (This could indicate a problem with the wiring, one or both of the two boards.) The parts list for the 665.1392 control panel is available here: . There may be other sources for the parts.
You'll need to open up the control panel to do any diagnostics. If your dishwasher is still under warranty, contact Sears for a service call.
I hope this helps.
Apr 26, 2016 | Kenmore Dishwashers
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a sears dishwasher, lock light is lit but
Press and hold the 'Heated Dry' button for 4 seconds then let go
Apr 24, 2010 | Kenmore Dishwashers
I have a top drawer and a bottom drawer type. My
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Oct 28, 2009 | KitchenAid Dishwashers
Filter light status
Please verify the model number for your fridge, as the description shows a Frigidare 24" dishwasher.
With the model number and you providing the different buttons on the front panel, I can provide you with the button sequence to push and hold to reset the filter light.
While waiting for the needed info for an exact solution, you can try this:
If you have a "light" and "lock" button, push and hold them together for several seconds, the filter light should go off or change back to green.
If not, please provide me with the brand and model number for your fridge so I can give you the correct procedure for resetting the indicator light, by responding back with a "comment".
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Frigidaire Professional Series 24 in....
A child lock is flashing with a red light and i do not remember setting it to lock. How do I unlock?
To prevent children from accidently changing the dishwasher cycle or starting the dishwasher, lock the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. An indicator light on the lock graphic touchpad will illuminate when the controls are locked and no new selections can be made until the lock is released. To unlock
please furnish the brand and model no of your dishwasher to be more sopecific
please rate this answer the controls, press the DELAY TIME icon until the indicator light goes out.
Jul 07, 2009 | Dishwashers
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
My Whirlpool quiet wash plus 940 series is stuck on "lock out"
Same problem and I was about to call for service. Opened the dishwasher to get the model number and noticed a sticker stating to hold down the Heated Dry button for 5 seconds to clear the lock light. Worked for me!
Feb 14, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Normal wash flashing Red
We have the same problem with kenmore model 66513839k600
we press light wash and normal wash lights up, we have to wait over a month for sears to service. This will be the second control panel they will install on warranty, a month is far too long a wait for service on any appliance.
Dec 03, 2007 | Kenmore 24 in. 17039 Built-in Dishwasher
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
267 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
