Question about Yamaha HTR-6130 Receiver
Subwoofer connection I just bought HTR6130B, yesterday and I started to connection all speaker and connections, however, the subwoofer connection is different, my subwoofer with the black and red type, how can I resolve this item, I cannot afford a new subwoofer now if there's any adapter can convert to different type of connection, please advise.
  • Mike Lynch
    Mike Lynch May 11, 2010
    Are you using a passive ( non powered) subwoofer or a Powered subwoofer?
  • 86 Answers
Deppending on the subwoofer, theres all kinds of converters, u can do this, take the subwoofer to a radioshack or call them and ask that u need a wire converter 4 example say rca converted into headphones & they will hook you up, saves alot of money 4 a say 15 to 20 doller item, and ur subwoofer will be blasting like no tomorrow
hope tha helps
Posted on Feb 14, 2009
I just bought my son the HMDX rave blue tooth speakers we got everything hooked up and hear music but it is skipping does anyone know why
Could be the distance or it could be the source. Do they make that sound when using bluetooth only? Connect to the AUX connection and see if that makes a difference. Also try using a difference phone or MP3 player as well.
Feb 25, 2016 | Audio Players & Recorders
Can I hookup a powered subwoofer to a Kenwood 105VR receiver?
Had you bought the 106 version that has a subwoofer out socket. Some subwoofers have options for connection by speaker terminals. If you haven't bought the subwoofer yet check with the seller to make certain you can connect it via speaker wires. Otherwise you would be better with a non powered one.
Aug 03, 2013 | Kenwood 105VR
Bought new Infinity 8" speaker
hook them up and play something,, the speaker should bounce "out" on bass sounds, if it pulls "in" switch the wires
May 04, 2011 | Infinity BU-1 Speaker
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
How to connect a mordaunt short ms907 subwoofer?
I guess you don't have the owner's manual for this?
You can get it here:
MS907 Subwoofer manual
The manual contains connection info.
Apr 27, 2009 | Mordaunt Short MS-308 Subwoofer
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
I-trigue 3400 speakers
My 3400 worked yesterday, but today the subwoofer stopped working. I tried a lot of different things. In the end, I simply had to jiggle the wired remote connection to the subwoofer and it started working again.
Jan 07, 2008 | Creative Labs i-Trigue 3400 Computer...
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
Yamaha HTR-6130 Receiver Logo
488 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
