I cant remember my gmail email address that i used for the phone,have made to many pattern attempts,now cant do anything except emergency calls
SOURCE: kids was playiong with G1 and did to many unlock
If you cannot remember the username and password to your G1, there is not a way to recover it at this time. The only way for you to have your phone again is to do a master reset using the hardware buttons. This will delete all of your data on the phone only (SIM card and memory card data will be fine). To do a master reset power the phone off completely. Hold the home key and the power key at the same time while turning it on again. You will see the T-Mobile G1 screen first, but them you will see a screen with a triangle appear. You can let go of the keys and open the keyboard. Press and hold the left ALT key and then press the letter W. Release both the keys and the phone will power off. Then it will power on again and act like you just removed it from the box. Create your new account and write down the username and password this time that way you wont forget it.
SOURCE: pettern lock
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: How do I unlock my xperia 10 after to many pattern
Try this site for your unlock needs. very good at what they do. http://www.unlock-zone.com/
SOURCE: describe how to unlock my
easy as pie download android sdk from google install it on your c drive under android sdk then download and install the usb drivers for your phone then right-click on "my computer" on your pc select properties select environmental variables highlight path select edit and ad in c:\androidsdk/adb/tools then plug in your phone to the pc open a command prompt via the run function on your start window and enter: command then type in "adb" press enter then type in "adb" devices then press enter at this point you can unlock your phone via an adb command listed in the command promps once you type "adb" then press enter ill link a youtube video its not as hard as it sounds its just not the easyest thing to walk a person through with a written discription. if you still dont feel upto it pay someone on craigslist 10 or 20 bucks to do it for you they will offer you the option to root your device witch is awsome but more dangerious or annoying than 90% of android users. sorry for the long explanation. here is your youtube link
