Question about Mitsubishi Televison & Video
Color lines. I have Mitsubishi rear-projection tv that has a tiny problem. But an annoying one.. In about the middle of the tv, there are 2 small parallel lines of blue that are roughly 2 inches long horizontally and about half an inch apart. On a blue background, I can't see them anymore. I have verified that the problem is not in the screen. I looked at the mirror and the color guns visually from the front of the tv, but I didnt really see any problems. What in the world could it be?
  • 1 more comment
  • David951 Feb 11, 2009
    I'm not sure how to access this. This is my tv model.
    Mitsubishi:
    Rear-projection
    HD 1080 series 46"
    Model: WT46805
  • David951 Feb 12, 2009
    I just dont see that control. Maybe I need the remote? I can only use the panel on the front of the tv.
  • David951 Feb 13, 2009
    Or another forum..
  • Mitsubishi Master
  • 5,138 Answers
Readjust screen control drives on screen and focus control R/G/B.
Posted on Feb 11, 2009
  • 1 more comment
  • ladywinn
    ladywinn Feb 12, 2009
    Focus&screen block control will have 3 controls on top are focus for RGB and 3 on bottom RGB screen control drives.
  • ladywinn
    ladywinn Feb 13, 2009
    I am thinking maybe you would be better off calling a repair person for your problem.
  • ladywinn
    your problem cannot be solved with a handunit , remove front panel on bottom of tv there is where you will find focus&screen control box.
Growing number (now six) small green dots on right side of screen of 65" DLP rear projection Mitsubishi HDTV. Annoying -- how to fix?
Replace Light Engine, pretty soon you will have Dots All over screen with green and purple color. Call UED for price of rebuilt Light Engine 1-800-648-6657 ask for Melissa tell her ladywinn said Hi.
Sep 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Jun 15, 2007 | Panasonic PT-47XD64 47" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
