Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
F2 code on a Kenmore 721 89952590
When started unit "runs" then throws a f2 code and seemingly does not heat
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for about 5 minutes. Then let us know if the hard
    reset does not fix it.
    There
    should be a "mini-manual" (tech sheet) hidden inside the unit
    behind the
    control panel or hidden on the left side behind the grille, which is
    very helpful when troubleshooting, testing, and locating components.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    The mini-manual will have a list of codes and will tell you what F2 means in this model.
5 Suggested Answers
MicrowaveSvc
  • 8934 Answers
SOURCE: Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Posted on Nov 25, 2006
  • 43 Answers
SOURCE: microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Posted on Feb 03, 2008
SOURCE: F2 WArning light on Kenmore Microwave oven
The light bulb already works, so this isn't the problem.
Posted on Oct 01, 2008
MicrowaveSvc
  • 8934 Answers
SOURCE: f9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
Posted on May 20, 2009
  • 3741 Answers
SOURCE: Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Posted on Sep 30, 2009
Kenmore microwave model 68680/12 is displaying code F2. Nothing on the control panel works.
Call the 800 # for Sears service. They should be able to tell you what that code is for. Bad key pad or door switch??
Jan 30, 2015 | Kenmore Microwave Ovens
A code of F2 appears on the LED clock timer - not always, but peridically every 30 seconds or so. I unplugged the unit, for 30 seconds, plugged it back in and it worked for about 20 seconds. Then the key...
F2 is a bad keyboard error code. Try this, unplug the unit, open the control panel and disconnect the ribbon cable from the control board, plug back in, if f2 comes back on the board needs replacing, if it does not, then the problem is with the keypad.
You can visit this link if you need any help regarding replacement of the touch pad.
Hope this helps. Thanks and have a nice day.
Jul 05, 2011 | Whirlpool MH1150XM Convection/Microwave...
F2 is appearing on microwave and its not working
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "F2 fault code".
Dec 13, 2009 | Whirlpool GH4155XP Microwave Oven
After not using for 2 weeks , display panel
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("F2 on display").
Nov 23, 2009 | Kenmore 63792 Microwave Oven
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 21, 2009 | Kenmore 63792 Microwave Oven
I have a Kenmore Elite Speedcook microwave model 63792-The display light beeps every few minutes and stays on rather than dimming after use. I unplugged and a message "call Service F2" came up-I used the...
Jul 13, 2009 | Kenmore 63792 Microwave Oven
F2 code on display - microwave does not heat
F2 on this model means you have a shorting membrane keypad.
On this model, the membrane keypad is available already mounted on a new control panel frame. It runs a little more, but saves a lot of time consuming and aggravating work.
In this case, you simply move your circuit board into the new frame.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove a few more screws and disconnect the wires.
It is part # AP3673562 (same as 8205018) and runs $80.97 + shipping here.
Feb 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Oct 01, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore microwave
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
53 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
