Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Need 2nd screen in Phillips 60 inch tv..not sure what it is calle
When moving this tv, the thin middle screen blew off, we didn't know it would do that, we need to replace it, apparently it is what makes the tv work. Have the inside screen and the big outside screen, not sure what the 2nd middle screen is called --and where to find to replace?
  • 3 Answers
I'm moving and the force of the wind pushed the screens out of my 60 inch Phillips projection TV. How do I fix it?
Remove the back of the TV and hot glue them in, make sure they are laying flush to the front of the TV, or you will notice the imperfections. Good luck!
Nov 23, 2014 | Televison & Video
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
The screen blew off my TV and into a million pieces while moving
I don't know what kind of t.v. you have but we have a panasonic 52 inch rear projection t.v. and when we bought it ( used) the one of the screens ( the outer - lenticular screen ) was torn and we had to replace it. Our T.v. has two screens and outer and an inner screen. The inner is more expensive. We used a company called Vance Baldwin and they were the most reasonable. We dealt with a man by the name of Odie Mills and the main office is in Fort Lauderdale Florida. The address is : Vance Baldwin, Inc. 7060 State Road 84 #12, Fort Lauderdale, Fl 33317 (954) 723-9191. Ask if they have a warehouse that deals with their products near you and you might be able to pick up the screen instead of having it shipped to your home. Be sure to check the screen before you take it though, we seemed to have a problem with damaged goods because the screen is so delicate. We ended up just having it shipped to our home and it was packed real well and didn't have a problem. I hope this helps in some way. Melinda
Oct 26, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
