Question about SAMTRON 55V 15" CRT Monitor
Samtron 45bn power regular on/off
I' ve  Samtron CRT monitor that has similar problem of rebooting. when power on of the monitor. then monitor automaticly on/off
  • ashish13
    ashish13 May 11, 2010
    does the system restart when you switch on the monitor or is the issue with just the display...
    President:
  • 414 Answers
Just replace the FBT FEA830 and check
Posted on Oct 20, 2009
    Problem Solver:
  • 5 Answers
You are service engineer please follow this first please check the switch in the pcb the switch is uplifted from the track also there is one of the reason it is situated in correct position and the replace the trigger chip in the board
Posted on Feb 23, 2009
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Samsung (samtron 5Ei ) rebooting & EMI problem at times it is O.K.
Check 5 v at 7805 output and change Memory IC (EEPROM).
Check SMPS o/p voltages
Sep 20, 2008 | SAMTRON 55V 15" CRT Monitor
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Using CRT monitor
try back to other machine again.
Apr 22, 2008 | Dell E176FP 17" LCD Monitor
Samsung 45bn H output transistot over hating and burning out after a fewminits
THE MOST ECONOMICAL SURE FIRE FIX IS TO REPLACE YOUR MONITOR WITH A QUALITY LCD SCREEN IT UTLIZES 50% less electricty AND RUNs A LOT COOLER.
IF THE HORIZONTAL OUTPUT TRANSISTOR IS BAD MOST LIKEY THE POWER CONTROL BOARD IS GOING BAD you may also have a bad resistor or diode allowing to much current on power control board
Jan 16, 2008 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
242 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
