what model and make ?
is it a taylor as this instruction manual link below explains the CO2 pressure on the 9th page which is page 5 in instruction manual. It mentions a primary regulator setting of 90 psi for the regulator and a secondary regulator pressure setting of 60 psi for the regulator.
it may be similar for your make and model . http://www.taylor-company.com/assets/pdfs/downloadables/0345_346_349_355op0.pdf
Turn the gas tank valve OFF by turning the tank valve clockwise. Then disconnect the hose from the tank valve and remove the tank from the grill. When reinstalling a full tank, do everything in reverse of removing it. In addition, once the hose is connected to the tank, open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Opening it quickly, can cause the grill's regulator to lockup and provide little or no gas to the burners.
Hope this helped you and Happy Grilling. Thanks for choosing FixYa.
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading. Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
