Question about Uniden Cordless Phone
"searching" message I have two handsets. One of them gives me a constant "searching" message. I have tried putting it on either one of the bases and it doesn't seem to make ny difference. The second handset seems to be fine.
  • jomo630 Apr 17, 2009
    I have a cordless GE phone model 28821 series. Dect 6.0 handset speaker phone & answering system.
    My second phone does not work. It just gives the time and when I go to use it, it displays "searching". Please help.
    Top Expert:
  • Uniden Master
  • 77,514 Answers
The handset is defective, the receiver has failed, no signal triggers the message.
Posted on Feb 11, 2009
Put a new battery in my phone, now it gives me an out of rane message. how do I fix this?
I don't know what model it is but try these:
1. Check the main base is powered up!
2.Take out the battery again and edit a few mins and return it. Place the handset on the base. Now try.
3. If that didn't work you are probably going to to reassign the handset to the base. Check your manual on how to do that.
Nov 05, 2014 | Uniden Cordless Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
We have a DECT 6 system with a base unit and five satellites. Suddenly the satellite phones don't work, but they are alive (with no dial tone and don't ring) and show a message "out of...
Hello.
From FixYa Support:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
Perform steps for each handset. You may need to plug base unit and unplug for each handset.
Hope this helps.
Jul 27, 2011 | Uniden Cell Phones
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Oct 23, 2008 | Philips CD6451B/05 Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
In Use LED flashing constantly
Your phone may have lost registration to the base. 1) Try disconnecting the power to the base and then re-connecting the power with the cordless phone in the base. Give it a few seconds, then see if it works. 2) Try removing the battery, wait 10 seconds, re-install the battery and set the phone in the charger.
Jul 07, 2007 | Sony SPP A940 Cordless Phone (SPP-A940)
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
197 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
