Question about D-Link DIR-625 (790069292637) Wireless Router
Network not Found
I have a D-Link DIR-615. For some strange reason it stopped broadcasting. Whenever I turn on my laptop, I cannot locate my network. I've checked all the configuration on the router and everything is the way it should be. I've called D-Link tech support to no avail. No one else seems to know the problem. I need help ASAP. Thanks
  • Anonymous Feb 16, 2009
    cannot find network
We have 2 laptops and not working on Connect, mix up on Dlink systems pls help me
Randy
Posted on Feb 24, 2009
    Sniper:
  • 96 Answers
Common problem. I had the same problem with various models of D-Link. If it is not becomes annoyingly often try to reset router and run wizard from beginning till the end
Posted on Feb 11, 2009
How can i fix dir 615 ssid stop broadcasting issue?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password
Step 3: Under Setup Select the Wireless tab
Step 4: On Wireless Tab - Select Invisible if you do not want the SSID of your wireless network to be broadcasted by the DIR-615. If Invisible is selected, the SSID of the DIR-615 will not be seen by Site Survey utilities so your wireless clients will have to know the SSID of your DIR-615 in order to connect to it.
Sep 08, 2014 | D-Link DIR-615 Wireless Router
How can i make my wifi unlock on my D-Link dir 615 wireless router
Login in using your browser using a LAN cable and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Dec 01, 2013 | D-Link DIR-615 Wireless Router
Can't have connection with modem
One of the most common reasons for Internet connection problems is incorrect login information. When your computer locates the network put out by your D-Link wireless router, you will be required to enter login information if the network is secured. The DIR-615 model supports WPA and WPA2 security information; if you can't connect, ensure that you do not have WEP security selected on the network settings
Mar 07, 2012 | D-Link DIR-615 Wireless Router
The Atheros AR5B125 wireless adapter is experiencing driver or hardware related problems.
LOSING WIRELESS CONNECTION
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Jan 20, 2012 | D-Link DIR-615 Wireless Router
I have a DIR 615 Dlink wireless router connected to a Dell computer running XP Pro. Checked for latest firmware, had it. About every 2 or 3 days it will stop broadcasting a signal and I can not logon with...
Ok this might be a bit tricky but it sounds like there is another wireless signal that may be interfering with yours.
Do you have an older cordless phone in the house? If so try and move the cordless base farther away from the wireless router. Even if they are on different floors in your house, if they are located near each other the cordless can interfere with the wireless signal.
The other possibility is that there is signal that is coming from the outside of your location and is causing the interference.
I know that when I had an XP Pro machine (Laptop) it would drop the wireless signal every couple of days or so. I traced my problem to my neighbors cordless phone. he had an old one and it was near the side of my house that my router was on and it was causing me problems so I move my router and the problem went away.
hope this helps
May 21, 2011 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
How to secure network for DIR 615 so it can't be used by someone in the neighbourhood. When I type in the PIN # that came with router it says it is unsuccessful
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Mar 07, 2010 | D-Link DIR-615 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
D-Link DIR-625 (790069292637) Wireless Router Logo
198 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
