Question about GE JVM1190 Microwave Oven
Ge microwave model JVM1190WY buttons work but does not cook
The microwave is about 5 yrs old, all buttons work fine, when pressing cook or any of the express buttons to cook, timer starts going down, we hear a clicking noise inside, but it does not cook. Any help out there please? thanks
  • 1 more comment
  • marcos311 Feb 11, 2009
    like a zapping noise like arcing inside the microwave where you place the food
    to be heated
    Hi, just wondering, is it worth to repair it , or its just on your opinion better to buy a new microwave? from your answer I gather that this is the "heart" of the microwave.
  • roberto serbin May 11, 2010
    Is clicking noise like a tapping noise or is it like a zapping noise like arcing inside the microwave where you place the food to be heated?
    Novelist:
  • 140 Answers
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
  • roberto serbin Feb 11, 2009
    The magnetron depending on its size and wattage will cost you from $40 to $65 not counting your time or someone else's time to repair. I would buy another one. The only other alternative is to find a used microwave like yours that has a different problem and take the magnetron from it and put it in yours. That is what I would do if I were on a tight budget and had the time to look. In that way the magnetron may cost you $10 or nothing if you get it at a local tv repair shop. Good luck and God bless you. Thanks for letting me help.
How do I remove a GE microwave to replace it?
Look under it and in adjacent cupboards from mounting screws. Some just pull out.
Here are the installation instructions for a similar GE Microwave
http://www.homedepot.com/catalog/pdfimages/d4/d4de3943-f969-4aae-a358-21d0712ed1c7.pdf
Oct 11, 2016 | GE JVM1190 Microwave Oven
GE Microwave manual
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 16, 2011 | Microwave Ovens
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Oven resets (like power failure) frequently - either while pressing buttons or while cooking food. Approx 5 yrs old - problem just started.
Hi.
The following parts may cause this problem and must be tested:
Control Pad: This is most likely the problem , testing the contol pad is quite complicate.
Door lock: A defective door lock can cause the magnetron and turntable motor being turn off erratically. This wont cause the program to reset.
Power cord and power connection solder joints: this can cause a microwave restarting because vibration caused by the oven working cause power interruption.
A bad shielding to controller board can also cause the microwave resetting because of the interference caused by magnetron on control board circuits. This is also quite common.
The control pad or control board are the parts that are most commonly causing this problem.
Dec 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work fine, and the light inside turns on. We can enter a cook time, and it counts down as if...
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Dec 28, 2008 | GE JVM1330BW/WW Microwave Oven
MY JVM1190WY MICROWAVE STOPPED WORKING SUDDENLY
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 29, 2008 | GE JVM1651 Microwave Oven
GE JVM1190 Microwave Oven Logo
644 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
